how do I get more horsepower??
Old Mar 24, 2001 | 05:18 PM
87firebird's Avatar
What is the best way to get more horsepower out of my 305 in my 87 firebird formula?? I'm getting a huge air cleaner and having dual exhaust installed. Is it worth it to put headers on, or is that just a waste of money??
Old Mar 24, 2001 | 05:22 PM
Blade's Avatar
A good way to get more horsepower is to open your wallet Headers is a good way to start. If you're getting an air cleaner I would guess you have a 350 TBI car. You should get a good catback exhaust system to go with the headers, then maybe a different cam, intake and throtle body. I heard the ones off the 454 trucks are bigger and can flow a lot more air. Try to post this in the TBI board.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Mar 24, 2001 | 07:38 PM
SUPER-SPORT-CHEVY's Avatar
Truth be told i have had many cars alot with headders and i have never noticed any difference in power or economy like the manufacurer says. i paid 800$ for custom headders for my departed 67RS and my Quarter mile times stayed the same. I would try a power chip if you have tbi that will improve performance compared to what headders are supposed to do.
85 Camaro RS T tops 350/350, stealth intake. holley street avenger 670. ported 58cc heads. comp magnum 270H cam,Crane 1.6 roller rockers,edelbrock accu-drive, MSD 6 series ignition on HEI, K&N extream air cleaner, true dual exhaust with 18 inch glasspacks.
82 Firebird 305/250 action plus intake, accel distributer with ccs 8mm wires foam air filter.
The only "cat" i have uses the litter box
Old Mar 24, 2001 | 08:10 PM
Biochem's Avatar
Car: 2002 SOM z28
Any stock 305 is going to wake up nicely with anything other then the stock headers! Headers, intake manifold (TPI?), 1.6 roller rockers, and a higher stall (2800-3000) converter are about the best mods that cost under $500ea that work well on a 305 that can be transfered to a 350. Heads are a waste on a 305, at that point just go with a 350+ shortblock too IMO.
Spray or supercharger are good ways to make power too.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
PurelyPMD
May 5, 2016 04:57 PM
dbrochard
Sep 25, 2015 04:56 PM
scottmoyer
Sep 5, 2015 09:33 AM
formula_novice
Sep 5, 2015 03:58 AM
1LE91
Aug 31, 2015 08:13 PM
