Thinnest available head gaskets?
Old May 19, 2004 | 03:17 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Can someone tell me what my options are for a thin head gasket for a 400 with aluminum heads? Part numbers would be greatly appreciated. Thanks !!
Old May 19, 2004 | 07:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I wouldn't go less than .015. Some 305 TBI guys use that thickness when they go with vortec heads. However, some blow them out in no time when their CR's get above 9.6:1.
Old May 19, 2004 | 07:31 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I would not put a thin gasket on an engine with aluminum heads, especially a 400. The center two cylinders are too close together to get a good seal. Deck the block or shave the heads & use a thicker gasket.
Old May 19, 2004 | 10:53 PM
wesilva's Avatar
Transmission: 200R4
Both the block and the heads are decked. The deck height is .025 and I was hoping for a .020" head gasket to minimize my quench. I'm about ready to go with the Mr. Gasket Ultraseal set but the compressed height is a whopping .040". Too much for me. I wish I could find something in a .030" without going to the expensive copper shim. I wish I would have zero decked but it's too late now. The shortblock is assembled.
Old May 20, 2004 | 04:44 AM
ede's Avatar
ede
i'd run a gasket made for aluminum heads and an iron block and not worry about the thickness. if i found two gaskets that met the aluminum to iron requirement then i'd get the thinnest, if that's what i as after. aluminum to iron causes some problems because of the differant expansion rates. it's not to late to have the block zero decked, you'd just need to start over. other than time there wouldn't really be any extra expense involved except the machin work.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
