High Flow Injectors
Old Mar 24, 2001 | 02:39 AM
idrag2's Avatar
High Flow Injectors
Hey whats up........the question I have are high flow injectors really worth the money. And will it make any noticable power in a stock 305? I have a open air filter, k@n, Stage 3 ADS CHIP, 160 stat everything else is stock in the motor. And if they will make a difference where can I buy them and how big do I need to go?
I DRAG 2
Old Mar 24, 2001 | 11:23 AM
Vader's Avatar
U Drag,
The GM Powertrain engineers did a respectable job in mathcing the injector flow rates to the displacement of the engine, except at higher RPMs. The injector flows at anything but WOT are a function of the ECM, not the injectors. The ECM will control the injector pulse widths to maintain the correct A/F ratio at all throttle positions up to 80% or higher. This is the only place that a higher-flowing injector or higher fuel pressure will really help. You basically stock 305 probably wouldn't benfit much from different injectors, unless of course yours are malfunctioning.
Old Mar 25, 2001 | 09:34 PM
idrag2's Avatar
Thanks man!!!!!
gta90
Sep 15, 2015 04:00 PM
db057
Sep 4, 2015 07:57 AM
Keith5
Aug 27, 2015 04:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
tmellott89
Aug 16, 2015 02:58 PM
