Idle/stall problem
Old May 21, 2004 | 11:14 AM
90ekm's Avatar
Idle/stall problem
Help. I have a 90 camaro with a 3.1L, when i come to a stop i would get a jumpy idle and would stall, i have cleaned the IAC, but still have this problem every so often, was running fine this am but completely stall when trying to reverse, any help would be appriciated. I have changed spark plugs,wires, rotor and cap.
Old May 21, 2004 | 01:58 PM
Nicki88's Avatar
Car: red 1988 Camaro
Engine: 2.8L V-6
Transmission: automatic
I had a similar problem last year with my 88 Camaro 2.8L. The rough idle and stalling always happened when then engine temperature was at least 150-160, and this always happened at stoplights and stop signs. The shop cleaned the throttle body and adjusted the TPS (throttle position sensor). This solved the problem. I also had the distibutor cap, rotor, and wires done about a week later, but just for maintenace reasons.
Old May 21, 2004 | 03:09 PM
90ekm's Avatar
Thanks for the response, i will look into it.
Old May 24, 2004 | 10:28 AM
90ekm's Avatar
anyone have instructions on how to set TPS? V6 3.1
Old May 24, 2004 | 08:01 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
go 2 electronics and trickster has given me the instructions on what 2 do
Old May 25, 2004 | 10:34 AM
90ekm's Avatar
thanks for the reply, but i am seeking to set the TPS.
Old May 25, 2004 | 03:39 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
yes he gave them 2 me 4 the TPS. go 2 my name and look at TPS?
Old May 27, 2004 | 04:53 PM
90ekm's Avatar
Took car by the shop, IAC was not getting a signal from computer, removed computer,cleaned terminals and all checks out OK.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
