head gasket??
Old May 22, 2004 | 12:08 AM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
head gasket??
Just wondering how do you know if you blew a head gasket or not?
Old May 22, 2004 | 12:48 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Compression test. Do a compression test on all 8. That will tell you if your leaking somewhere in there.
What makes you think you blew a head gasket?
Old May 22, 2004 | 07:03 AM
ede's Avatar
ede
compression or leak down test. you can also use a exhaust gas locator in your cooling system.
Old May 24, 2004 | 09:13 PM
Engine: 350 carb
i dont know...like it over heated really bad and also blew a carb fire....just wondering how would you know, how do you do a compression test, a special tool or something?
Old May 25, 2004 | 12:13 AM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
You do need a special tool to do a compression test. There are a lot of compression testers on the market. You want one that screws into the spark plug hole and has a hose, rather than the kind that you have to hold in the hole. Sears sells a kit that fits most cars.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
