New Cam ??????
Old Mar 26, 2001 | 02:39 PM
CloudIROCZ28's Avatar
New Cam ??????
Does anyone new a really good cam that will give me a more better sounding Engine preferably a Comp Cam I've got a 305 TPI and am Wondering which will give me the most power and actuaqlly about how much should I expect out of it???
Old Mar 26, 2001 | 03:32 PM
Dan87IROC-Z's Avatar
I don't know about any from Comp Cams (althougth I know there are some), but there are lots of cams you can run in a 305 TPI motor. You can look into the LT1 and LT4 production cams, they are good ones for a 305, assuming you have some exhaust and intake mods. My friend is running the smaller of the 2 SLP Cams sold in Summit in his 89 IROC, and has had great success with it, even though its close to $400. I wouldn't do a cam swap unless you have a cat-back system and a set of headers at the very least, but thats just my 2 cents!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
