besides vats, what signals does ecm need to start?
Old May 22, 2004 | 03:28 PM
jdub2027's Avatar
Car: 91 Firebird
Transmission: auto
besides the VATS, what sensors/signals tell the computer that it is ok to pulse the injectors? i have a 91 305 TBI automatic. thank you!
Old May 22, 2004 | 08:38 PM
onebinky's Avatar
IIRC, that's it. There is an oil pressure switch above the oil filter that won't allow the pump to prime if it doesn't register presure, but I think that the only thing that will prevent injector pulse is VATS.
You do have 2 injector fuses in the fuse box.
Might want to test at the ECM to make sure the injector drivers are firing, that will rule out an issue with wiring.
Oh, almost forgot. If the impedance is to low on an injector, the injector driver will not operate. Test the injector coils to see what the resistance is.
Old May 22, 2004 | 08:42 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Sounds like that isn't doing something it's supposed to. Care to trouble shoot?
Old May 23, 2004 | 12:30 PM
jdub2027's Avatar
Car: 91 Firebird
Transmission: auto
thanks for the great ideas. heres some more details. my car is a real pain to start in hot *weather*. strangly, it starts fine if its "hot" (i.e. been running). i narrowed it down to its not getting fuel. i then figured out its not the fuel system cause i finally got a noid light hooked up to it while it wasnt working and the light wasnt flashing. so i believe my ECM or some sensor is over heating in the hot weather cause i reached under there and the ECM was HOTTT.
Old May 23, 2004 | 12:31 PM
jdub2027's Avatar
Car: 91 Firebird
Transmission: auto
isnt there a distributor reference signal or something? could that module be overheating? im thinkin its the ecm but i just wanna consider all possibilities.
Old May 23, 2004 | 12:43 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Check to see if you get spark when you are not getting a flash from the noid light. The module inside the distributor may be causing the problem. Also check to make sure none of the injector windings are shorting out when they get warm.
Old May 23, 2004 | 05:13 PM
Vader's Avatar
Yes, you need to have power from the INJ1 and INJ2 fuses, a distributor reference signal, power to the ECM, and a valid VATS input.
If you are getting spark to the plugs, the distributor is at least generating a signal. You need to make sure that signal is getting to the ECM.
Orr89RocZ
Apr 25, 2016 08:28 AM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
