strange noise
Old May 23, 2004 | 06:01 PM
sephiroth99's Avatar
Car: 86 z28
Transmission: t-5 original
strange noise
Hi, I just was wondering if someone might have a solution to a problem i am having. The other day i took my car out for a ride and everything was fine until i put it in 5th gear, then everytime i hit gas it would make this loud noise almost like i was driving a truck. The noise is hard to describe except that it sounds like a diesel everytime i hit the gas and it only makes this noise in 5th gear. Does anyone know what problems i might be having? i have an 86 z28 350 4bbl q-jet with original 5 speed manual trans.
Thanks for any info
Old May 23, 2004 | 11:58 PM
onebinky's Avatar
How fast are you going when you put it in 5th? Sounds like you're bogging the motor.
Old May 24, 2004 | 08:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The description sounds like spark knock.
Too much timing advance. Back it off a bit until it stops.
These are the paths of wisdom.
Old May 24, 2004 | 12:42 PM
Car: 86 z28
im going about 50-60 when going into 5th. It does sound like it might be bogging but I won't say for sure because I don't know but would backing the iab out a bit help any? I tightned it before it started making the noise and also set the idle screw higher for a higher idle but since have backed the idle screw out again. If it is the iab how do i go about fixing it? Like how many turns from the bottom should i back it out? Thanks
Old May 25, 2004 | 12:19 AM
Car: 86 z28
one more question would making the car run lean allow me to use less fuel?
Old May 25, 2004 | 12:24 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Thats exactly what running lean means... less fuel. But thats a dangerous way to try to improve gas mileage. That too can lead to detonation (knocking).
Old May 25, 2004 | 01:14 PM
Car: 86 z28
argh i cant figure this out. It uses alot of fuel when it is idle and even more when getting around, I have no clue what the hell could be the problem. I mean so much fuel consumption just from the iab? I'm getting kind of agitated seeing as I have to make a 3 hour trip this weekend. Hopefully I can get this solved soon. Any suggestions would be great, Thanks
Old May 25, 2004 | 04:58 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
to me it sounds like your running it rich and you adjusted you IAB inward before it started doing this and it didn't do it before.. I would adjust it outward ruffly the same number of turns you adjusted it inward....set it back to where it was.. also to note I'm **** drunk right now so take my advice with a grain of salt. thanks!
Old May 25, 2004 | 05:03 PM
89RsPower!'s Avatar
do you have a dwell meter? what is your dwell currently set at?
Old May 25, 2004 | 05:12 PM
Car: 86 z28
I don't have a dwell meter but i might have to go pick one up they are frickin expensive though like $30-40 and i prob just need it this one time. But ill see if i can get my refund for it seeing as I'll only need it for 1-2 days. But if don't scrounge up enough money for one I'm just going to have to try fiddling with the iab again. Thanks for the help
P.S. if i do get a dwell meter what should the dwell be set at?
Old May 25, 2004 | 10:24 PM
Car: 86 z28
would this be the type of dwell meter I would need to get?
http://www.canadiantire.ca/assortmen...rtment=primary
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
BWilcox
Sep 20, 2015 12:19 PM
