Brake Line Leak
Old Mar 26, 2001 | 11:25 PM
pookey's Avatar
Brake Line Leak
My front drivers side break line has sprung a leak and guess how I found out. It appears to be coming from the flexiable line into the caliper. How hard of a job is this to replace?
Old Mar 27, 2001 | 12:28 AM
GOLD85's Avatar
easy. you need to unbolt the line from the brake caliper and unbolt the line from the hard line from the master. use flarwrenches to unbolt the line from the hard line. this whole procedur sould take you less than a half an hour. after bleed your brakes and your good to go
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
Old Mar 27, 2001 | 06:00 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If its leaking from the crimp where the rubber is crimped to the metal collar, than you just need to replace the flex line. If its leaking where it meets the caliper, then you just need new copper washers. If you get a new flex line, it should come with copper washers as well. DO NOT reuse copper washers.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Reddeath210
Oct 6, 2015 08:20 AM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
