Emissions
Old Mar 27, 2001 | 08:24 PM
Team FTS's Avatar
Emissions
Here in Miami we dont under go emissions testing anymore i wanna know if removing the smog pump and related equipment such as A.I.R will help performance and how will it effect driveability?
Old Mar 27, 2001 | 09:27 PM
Enkil's Avatar
You'll get *VERY* little performance and probably no effect on drivability.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Mar 27, 2001 | 09:33 PM
GTAMAN63's Avatar
I agree, the difference will not be noticeable. I'm sure it helps a little bit, but not enough for sop. I took mine off to get rid of the stupid air hoses. Every time I had to access the passenger side header they were in the way. Much better now. Still pass the sniffer at e-check too!
Barry Izold
89 T/A, GTA
Modified 350/T-5
[This message has been edited by GTAMAN63 (edited March 27, 2001).]
Old Mar 27, 2001 | 09:49 PM
KW87GTA's Avatar
Hey, for you guys that have taken the pump out and or disconnected it, what did you do with that little thing that holds the solenoids? More importantly, what did you do with them? I was thinking of doing this too, although, probably just take the belt of the pump, cause I don't think I will pass emissions without all that stuff, unless anyone knows otherwise? Help please, thanks.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC,
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old Mar 27, 2001 | 11:40 PM
GTAMAN63's Avatar
KW87GTA,
Just remove that little black box and hide the wires. I asked the same question on this forum earlier and nobody responded with any problems. No ses light, no driveability problems. You would be surprised about passing the sniffer without the airpump. If you pass it now, I'm willing to bet you will pass it after removal. Take off the pump and all the hoses and clear up the engine bay. It's not that hard to put back on if you fail e-check, but I doubt the pump would be the cause of you failing. My GTA passes on fast pass, not even remotely close to failing. Stock converters/no smog pump. If you have a visual check however, it could cause some problems.........
Barry Izold
89 T/A, GTA
Modified 350/T-5
Old Mar 28, 2001 | 12:17 AM
Bort62's Avatar
hmm, GTAMAN63, I Know that guy!
Remvoing the smog pump is More of a Clutter issue than anything else, But wont cause any problems.
keep in mind the pumps like to seize up if they arent used, So if you take the belt off, Dont count on it working later.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 28, 2001 | 12:25 AM
GTAMAN63's Avatar
Bort,
He he If only the "other" board knew about this.......... Good to have another F-body person over there!
Barry Izold
89 T/A, GTA
Modified 350/T-5
Old Mar 28, 2001 | 03:12 AM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
Thats right the air pump seizes up almost instantly if you just diconect the belt so I pulled out the whole system. Funny how the more stuff I remove the better the TA goes.Also one less belt to drive and I noticed on a ***** out two way trip of 1400kms that I used to make every second weekend that I saved about a quarter of a tank of gas!
84 Trans Am HO L69 WS6
5 Speed manual
Vortech Cherrybomb no cat
Removed A/C A.I.R. Hdflap
H/made cld air induction
K&N
Otherwise STD
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
