big money engine swap. whats your opinion?
Old May 26, 2004 | 09:41 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ok IF i did this, it wouldnt be for a long time, talking a couple years.
but the big idea is, swapping an ls2 into my camaro?
you know.. thew new 6.0liters that come in the 05 vette
Old May 26, 2004 | 09:57 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Ummm.. why not just toss in a ramjet 502, or build a 454 and go DFI, or a nice low compression 383 and twin turbo it... The logistics of what you are saying is as hard, if not harder than the suggestions above. Any particular reason, or is it the being different factor?
Old May 26, 2004 | 09:59 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
LS2's are gonna cost a crapload until they have been out for a while and a supply builds up. Good luck ever finding one. There also going to be very compicated engines with lots of sensors wiring a computer controlled crap.
Old May 26, 2004 | 11:20 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Yeah it sounds like a cool and unique idea but the fact of the matter is its going to be near impossible to pull off. I would just build a nice big inch small block with a holley stealth ram setup, it would cost less and would be easier to do. Good Luck.
Old May 27, 2004 | 02:15 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
why the LS2?
if you want a GENIII 6.0L engine, get a 6.0L out of a truck, a good set of heads, a bigger cam, and a LS1 style intake. Volia, an engine almost identical to the LS2, but wait...... more power.
Or spend 1/2 as much and buy a GENI SBC and make about the same power.
Old May 27, 2004 | 05:50 AM
ede's Avatar
ede
red you fail to understand when you're 19 years old you can do anything and there is no obstical that can't be overcome.
Old May 27, 2004 | 08:18 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
jesus ede your sarcastic posts are crackin me up today.. now I gotta clean the coffee out of my keyboard that you made me spit all over it. thanks! :hail:
Old May 27, 2004 | 12:26 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
That was sarcastic? I thought I was just slow.
But hey, we must respect our elders right ede?... Ede?... EDE?!?! Dammit, wake him up!!
Old May 27, 2004 | 12:34 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Exactly. Sure sounds cool in your head but think about how expensive and complicated it'll be... For a 1/4 of the cost you could build a regular motor of the same performance and strength so why do it? Just to say you have an LS2? Are those 2 letters and 1 number worth the PITA and the massive amounts of money involved? I don't think so.
Old May 28, 2004 | 08:09 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Especially a PITA considering that Cali smog requires that all the parts of the fuel / ignition / emissions system are included in the swap as well as the tranny that comes with that engine.
The smog ref will see to it that your life becomes extremely complicated.
For the cost, and labor, by the time you're done with that swap, you could have put a payment down on some beach front real estate and have something that would increase in value instead of depreciate.
Or you could swap a viper engine into your car.
Jake_92RS
Jan 28, 2020 10:37 PM
onefreakz
May 14, 2018 12:15 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
