Help! Gas poured out of throttle body!
Old May 26, 2004 | 09:41 PM
DJXero's Avatar
Car: 1992 Camaro Z28
(Note: TPI)
I pulled the air flow connector(I don't know the proper name) that goes from the air filters to the throttle body, and a ton of gas poured out from the throttle body! I had an injector leak, and replaced the only injector that was bad (I thought) ,and the morning I did the job it did the same thing, the entire throttle body and plenum had gas in it. I thought a leaky injector wouild be the culprit, but could it be something else? What's going on????
Old May 27, 2004 | 02:16 AM
DJXero's Avatar
ttt
Anyone?
Old May 27, 2004 | 06:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Either the fuel pressure regulator is leaking through the diaphragm and is filling the plenum via the vacuum reference line. Or the charcoal canister is filled with fuel and is pouring into the plenum.
Can just pull each of the line off and check for the presence of fuel.
RBob.
Old May 27, 2004 | 03:09 PM
DJXero's Avatar
If the charcoal canister is filled with fuel, what does that mean?
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
