best way to get to the disturbtor bolt is?
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ok im real frustrated this small project of mine was only supposed to take 2 days max well its been 2 weeks and its soared into the several hundred dollar range...from machine shop work and buying a crap load of tools ...started out as simple egr replacement now its i have to remove the whole intake manifold for gasket well i cant get to the disturbtor bolt before i buy more tools what is the best way to get to the bolt on my 89 iroc 5.7 tpi and the ignition or coil is out side of the disturbtor not inside or ontop....
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
well i have always used my own mustard to cram my hand in there but you can buy a special wrench or you can heat up the proper wrench and bend it so that it will work.
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Or if you're cheap like me... go to a store that sells cheap wrenches, buy a 9/16, take it home and bend it.
If you have an extra laying around, that's even cheaper.
I bent mine in almost an L the bottom part being the box end, that I put on the bolt, then the top part being the open end, which if the bolt is too tight I use a pliers on to turn it.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Originally posted by thirdgen88
Go buy an offset distributor wrench at any parts store... They're really handy.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yea, ive seen them at autozone before. I can just do a bit of twisting and use a standard wrech to get at mine.
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
They have them at sears too. Here is picture of what your looking for:
Craftsman 9/16 in. Distributor Wrench
Sears item #00947683000
Mfr. model #47683
Craftsman 1/2 in. Distributor Wrench
Sears item #00947682000
Mfr. model #47682
Mfr. model #47683
Mfr. model #47682
Transmission: 4L80E/4L80E
Originally posted by CaptPicardsZ28
Could you be more specific as to where? Around here where I am noone sells a tool like that.
There are some tools that, if you do any sort of work yourself, you should not do without (filter wrench, jack stands, pliers, etc.). This is one of them.
Engine: 5.7tpi 350,
hey thanks everyone....i went over and bought both the 9/16 and the 1/2 gotta return one i guess...finally got that damn intake manifold off....i felt so happy i jumped up and down screaming....now i have a million sensors and things taken off and my engine is naked hehe.... and gasket to clean and stuff to do...how do i get rid of the gasket material with out anything falling into my intake and clean that oil and coolant **** up....
Originally posted by five7kid
Someone give him the coordinates so he can beam one over...
"Commander Ryker, warp 8 to Sears."
Mfr. model #47683
Mfr. model #47682
Mfr. model #47683
Mfr. model #47682
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
What kind of Captain can't spell his first officer's name?!?
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
