113 heads and lt4 valves?
Old May 28, 2004 | 09:09 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
i am putting together a 383 with a converted lt1 intake, cc306 cam, and 113 heads that have extensive work done to them. i know i will have to have the heads cut to fit the larger valves- but other than that- lt4 valves will work won't they?
Old May 28, 2004 | 09:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Why some kind of stock valves? Why not something good if you're going to go to all that trouble and expense?
Old May 28, 2004 | 09:37 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
the lt4 valves are larger than the 113 valves- not a lot- but every little bit helps. the lt4 valves are hollow/sodium filled- so they weight a lot less and get rid of the heat a lot better than the stockers. that plus the fact that i can get a new set of lt4 valves for next to nothin. my main question was about fitment- are the longer or anything like that- than the 113 stock valves?
Old May 28, 2004 | 09:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Stock length for SBC valves such as the ones that come in 113s is 4.910". I don't know about the LT4 ones.
lt500r55
Sep 1, 2021 01:30 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
