Car stumbles between 900-1100 when cold
Old Mar 30, 2001 | 07:49 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
If I start the car is will stumble for the first 5 minutes when its cold, but after that runs great. Any suggs?
Old Mar 30, 2001 | 06:29 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
carburated or injected? its an enrichment problem.
Old Mar 30, 2001 | 07:22 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
89 350 TPI.
Old Mar 30, 2001 | 09:42 PM
Car: 85 IROC
first thing you should do is check the ECM for any stored trouble codes. jumper pins A&B together at the diagnostics terminal. turn your ignition on but dont start the car. watch your check engine light, it will flash once, pause, flash twice = code 12. this tells you it is in self test mode, it will flash 3 sets of each stored code.
[This message has been edited by bottledpower (edited March 30, 2001).]
Old Mar 31, 2001 | 12:16 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
No codes or anything. this started after the intake and injector project. No vacume leaks. O2 is good at 010-840. Idles straight at 550. Timing is at 8* and TPS at .54. No ses light or anything. I'm thinking maybe MAF
89 FORMULA 350 Edelbrock Cat-Back ,March Pulleys,Super Coil,MSD 6AL ,Edelbrock TES's, AFPR ,Shiftkit, Edelbrock Base ,AS&M Runners, Edelbrock Waterpump, ,Crane Gold 1.6 RR's, BBK 52mm TB , MSD 22# Injectors ,Hoping for 13.5
Wade787b
Sep 29, 2015 01:15 PM
squiggy2
Aug 9, 2015 09:30 PM
86Base
Aug 8, 2015 01:34 PM
drathaar907
Aug 6, 2015 04:20 PM
