HELP!!!!!!!!!! Timing Cover
Old Jun 2, 2004 | 09:38 PM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
LOL this might sound dumb but i pulled my timing cover off to change the cam and now i cant get it back on!!!!!!!!! any tips or something special i need to do? the bottom wont get over the oil pan. anything would help cause now im stuck thanks
Old Jun 2, 2004 | 09:43 PM
Raiden's Avatar
That is normal. First, read your repair manual. To over come any troubble, I cut the corners off of my timming cover. The lip on the timming chain cover that goes over the oil pan gasket, cut a straight linedown from the corner of the lip and smoth it out so it does not cut into the gasket. Now, losen the oil pan nuts almost completley out, but not all of the way. At this point, you can wedge teh timming cover back over teh lip of the oil pan gasket. it's a beotch, but with tiime and patients, you can do it. good luck!
Old Jun 2, 2004 | 10:11 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
we just always take out the first 3 bolts on the oilpan and loosen the rest up pretty well then pry the oil pan down enough to put the timing cover in and put some sealer onthe pan gasket where it pulled away and rebolt every thing back up .......and ive seen lots of people cut the timing cover like Raiden said and that works really good too just do as he said and make sure you dont cut that front gasket at all so there you have two different ideas ......
Old Jun 2, 2004 | 11:39 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Agreed with the two above posts. I cut the lip off of my timing cover and just made sure to put a healthy dose of sealer and let it dry No leaks. The best way is to lower the pan.
Old Jun 3, 2004 | 01:28 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
thanks for the help i tried loosening the pan and it didnt work so i will cut the cover ...... thanks for the help
Old Jun 3, 2004 | 02:11 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I always cut the cover and the gasket a little bit. Then just to ensure its sealed good I'll take some gasket maker and put a bead over where the oil pan and timing cover meet. Never had a single leak.
Old Jun 3, 2004 | 03:01 PM
Engine: 355, 305
Axle/Gears: 3.73, ?
awesome it sounds like a good plan to me thanks everybody!
Old Jun 3, 2004 | 03:28 PM
ChallengeR's Avatar
Car: Trans Am 87
Engine: 305 soon to be 350
Transmission: 700R4 soon to be T5
I make this and....it fuc**ing leak!!! the oil goes out and jump on the headers at high speed or high RPM....i have to redo it...but now....y pull the engine and redo it like it have to had done i think its the best way....
My 0.02
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
