hard start tips
Old Mar 29, 2001 | 04:21 PM
84ZCam's Avatar
hard start tips
anyone got a good list of things to do to help get a 3rd gen to start up on the first crank (without having to stand on the gas pedal)? i always hear the mechanics' cars start right up on the first crank no matter how old their car is. i'd like mine to start on the first crank too! it's just something that a good running car should be able to do IMO. my 84 Z28 is in great running condition for having 160k miles on it but i hate the embarrasment of having to crank the engine a couple of times for 15 seconds to get it going in the morning. any tips would be greatly appreciated!
Old Mar 29, 2001 | 04:55 PM
rezinn's Avatar
Set your timing to factory default of 6*
Old Mar 29, 2001 | 06:30 PM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
Chuck a 13 plate battery in it.
Old Mar 29, 2001 | 06:45 PM
biotic's Avatar
Put a msd blaster coil on it, and/or ignition
Old Mar 29, 2001 | 10:46 PM
ArnoldBraker's Avatar
I would also suggest looking to see if your injectors are leaking. If they are they tend to flood the engine.
Old Mar 30, 2001 | 04:16 PM
Timmys88Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ArnoldBraker:
I would also suggest looking to see if your injectors are leaking. If they are they tend to flood the engine. </font>
would that make it start hard when the motor is warm (like after during the day when I've been driving...)?
It fires up strong when cold or its been sitting for quite a while. And usually starts fine if its only been sitting a matter of minutes. But when its been sitting say... half an hour or longer, it takes a while.
Tim Currie
1988 Iroc-Z
-350
-T-Tops
-'Free' Mods
The Score 12/1 and 1 Tie
14.76 @ 91 mph (you figure it out?)
AIM TCurrie1
ICQ 67616089
"Steer with the rear wheels"
Old Mar 30, 2001 | 04:21 PM
84ZCam's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Timmys88Z:
</font>
i've heard that this is usually caused when you're running a little on the rich side. you start right up when you're cold because a rich condition is GOOD when starting cold, but you'll have difficulties starting with a rich mix if you're already up to operating temp.
someone please correct me if i'm wrong.
Old Mar 30, 2001 | 04:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Proper starting technique is a good start.
Push the gas pedal slowly to the floor about 3 times, plus one more for every 10° below 50° ambient. Then try to start it.
If that doesn't work, then the problem is probably the plugs in the bottom of the fuel bowl. They leak. They will let all of the egas in the bowl drain into the intake, then when you try to start it, one or 2 cylinders have a load of fuel, but the carb is dry; so you have to crank it for long enough to get the fuel pump to fill it back up. This same problem will make the car hard to start after a hot soak of a few minutes, because the leaking fuel will flood the engine.
ICON Motorsports
Old Mar 30, 2001 | 04:42 PM
84ZCam's Avatar
great info RB, thanks! i think i'll start with the carb plugs and see if there is any leakage. i've got to pull the carb to do my intake gasket this weekend anyway.
ARNOLD: i'm having a bit of difficulty finding the injectors on my 305 4bbl. hmmm...maybe they're in the trunk with the spare
Old Mar 30, 2001 | 10:32 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
you shouldnt leave your injectors in the trunk, too much moisture back there. keep them in the glove box like i do.
Old Mar 31, 2001 | 01:27 AM
No you just not looking hard enough for them in the right place for your injectors. I KNOW for a fact your 4bbl has injectors:-)
Really though, I didn't realize you had a carb:-)~Arnold
Timmys88Z:
"would that make it start hard when the motor is warm (like after during the day when I've been driving...)?
It fires up strong when cold or its been sitting for quite a while. And usually starts fine if its only been sitting a matter of minutes. But when its been sitting say... half an hour or longer, it takes a while."
From what I have read, it certainly could. That actually sounds almost exactly like what my car does. The way to tell is to do I fuel pressure test. If it leaks off, then either your FPR is bad or your injectors are leaking. At least that is my understanding. What 84 Zcam said also sounds like a good possibility. ~Arnold
Old Mar 31, 2001 | 04:40 AM
Timmys88Z's Avatar
Ok, so lets say my injectors are leaking....
Can that be fixed? Or do I need new injectors (expensive!) ?
Thanks.
Old Mar 31, 2001 | 03:53 PM
Timmys88Z's Avatar
top
Old Mar 31, 2001 | 08:09 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Generally they leak because they got dirty (as in dirt, not a sick mind) Surf over (don't drive) to www.cruzinperformance.com They can clean and flow match your injectors for about $80
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
SLP 1 3/4" headers, 3" cat back (stock cat )MSD ignition. MSD Blaster SS coil. More soon when funds are avail...
Old Apr 1, 2001 | 12:56 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Wow! Gotta love that transition into fuel injection....
A carb? Ohh yeah! O got a carb. it's C.O.# 3330-334223.....
(The everlasting assumption 3rd gens are fi)
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
