Car shuts off and won't start for a while
Old Jun 5, 2004 | 10:01 AM
Accused Normal's Avatar
From: New York, Long Island.....over there somewhere...
Okay, I have this messed up problem. My car will run great for about a mile, then shut off. I can start it again and drive like 5 feet before it shuts off again. That will happen maybe 5 time and then it won't start at all, but if I wait a few hours it will start with no problem. But the same thing will happen after I drive a mile. WTF? Anything can only help me here, I'm stumped.
Old Jun 5, 2004 | 10:39 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
How's the ignition module? They have a nack for on and off behavior like that. Once they get a bit warm they tend to just 'fail' for a bit.
Old Jun 5, 2004 | 11:04 AM
ede's Avatar
ede
yeah i agree have the module checked or just replaced. replaced would be better since it only seems to fail hot and you'd be testing it cold.
Old Jun 5, 2004 | 03:40 PM
The ignition module is the chip that's in the distributor, right?
Old Jun 6, 2004 | 09:32 AM
Okay, so I changed the module in the distributor, but the car won't start now. Maybe the new one is bad cause it should start with the car being cold.
Old Jun 12, 2004 | 10:05 PM
I changed the module in the distributor now with a brand new one. The car won't even start. It just cranks. Please help!!!!!!!!!!!
Old Jun 12, 2004 | 10:27 PM
You think it could be a bad coil?
Old Jun 12, 2004 | 10:53 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
First, take a deep breath and calm down.
Second, did you use the gresae when installing?
Third, have you pulled the codes?
Fourth, (did I mention take a deep breath) Check your fuel pressure after the stall?
Fifth, have you tested for spark?
Sixth, if it still does not work with the new one, put in the old one.
Seventh, pinch the fuel return line a little after a stall and try starting then.
Eighth, After the stall and you start it, will it stall if you place no load on the motor?
Ninth, come back and let us know.
Sadly, I didn't put them in order, but rather, typed as I thought. You get the idea though.
Old Jun 13, 2004 | 10:50 AM
Actually I didn't use the grease. What kinda grease is it and what's the difference if I didn't use it?
Old Jun 13, 2004 | 11:03 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is a silicone grease and is used to cool the ignition module. Result of not using the grease is a overcooked module that won't work,
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Its a special grease that comes with the module. It deflects heat away from it. Without it, it will fry the module.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
