valve cover torque setting?
Old Jun 5, 2004 | 04:37 PM
warlord's Avatar
Car: 1983 Trans Am t-top
Engine: 305 4bbl carb (vin code H)
Transmission: 4 speed automatic
i have an 83 trans am with the 305 and i need to change the valve cover gaskets.
my problem is that i do not know the torque setting in lbft or nm, as the shop books i have say an 83 does not have gaskets but uses sealent, but i have gaskets. at least that is what i was told as the car has not arrived yet.
can anyone advise on this?
Thanks.
Old Jun 5, 2004 | 04:59 PM
ede's Avatar
ede
WAG 50 in/lbs ought to work for you. i never really used a torque wrench on the valve covers, 1/4 drive tools and not any excessive force will work for you.
Old Jun 6, 2004 | 01:09 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Put sealer on either side of the gasket, and snug it up. Once its cured (more or less) then tighten it up some. It doesn't really matter how much you torque the bolts, because they aren't under any stress or anything.
Just tighten them untill it feels tight, then leave it. If you go too far, you can warp the valve cover and it could leak a little.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
