Help!!!!! Belt Question!!
Old Jun 5, 2004 | 08:39 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
ok so I THINK my A/C compressor seized up.
so quick question:can i just get the non a/c belt verison for my car? or are things different of what?
Old Jun 5, 2004 | 08:45 PM
Borsty's Avatar
Car: 89 Trans am
and how exactly can i tell if the ac did seize up, the belt was smoking from there before it snapped off on the way home.
but it also kinda seemed like the alternator was sezied up too. anyway to tell that either?
Old Jun 5, 2004 | 09:57 PM
Vader's Avatar
Remove the belts from the questionable accessories and see if you can turn the sheaves by hand.
Old Jun 5, 2004 | 10:43 PM
Borsty's Avatar
Car: 89 Trans am
^lol the seized up access. already took the belt off for me, i had a nice ride home with no alt, p/s, or water pump.
Old Jun 6, 2004 | 12:20 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
With the car off and the belt either off or on, you should still be able to turn the central part of the a/c compressor by hand (the part that stays still when you have the car running with the a/c off) with a little force..
Old Jun 6, 2004 | 08:58 AM
Borsty's Avatar
Car: 89 Trans am
ac seems fine but the only belt driven acess that dont move is the one with a arrow pointing to it. is it suppose to move? my dad said masybe its a glide wheel but idk.
Old Jun 6, 2004 | 10:06 AM
thirdgen88's Avatar
Car: 1995 Corvette
If that pulley has three little bolts attaching it, thats your smog pump and they can have a tendency to lock up when they get old. They're not that expensive and its a lot better than your a/c being locked up..
Old Jun 6, 2004 | 10:52 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
sounds like your belt tensioner locked up on you if so its a common thing to have happen and you can go to an auto parts store and pick up a new one but they can be a little pricey any where from 50 - 100 bucks but that maybe what you got there not for sure without a pic thou
Old Jun 6, 2004 | 07:59 PM
thirdgen88's Avatar
Car: 1995 Corvette
Its not the tensioner if its in that relative position (beneath the a/c compressor... the tensioner is to the drivers side of the a/c compressor).. It would be the smog pump (but check to see how the pulley is attached to make sure like I said).. However if it is the tensioner pulley, you can go to a parts store that sells bca/national bearings and ask for a S203FF (its like $5). Then a hammer and a couple sockets later, you have a fresh tensioner pulley..
Old Jun 6, 2004 | 11:27 PM
Borsty's Avatar
Car: 89 Trans am
yea it was smog pump, after i get a replacement bottom bolt for the new smog pump my car will be back tearing up the streets again
thanks guys!
oh and the somg pump was 45$ 15$ core at autozone.
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
