Lopey Idle Cam on TBI
Car: 90 RS
I have a 90 RS with the 305. I'm wanting to install a cam and was wondering if I can get away with a (lopey-idle) cam on the TBI or is I should convert to a carb set-up to gain better performance in the upper rpm band?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
As desirable as the "muscle car lope" may be, lope and fuel injection don't usually get along too well without proper tuning of the PROM. If you want lope without the PROM burning, switch to carb. If you want to keep the TBI, either get a cam that is compatable with the stock fuel/spark tables (generally a smaller, non-lopey cam) of get into PROM burning.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by Vader
ThridGen TBIs are all S/D.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Also TBI can't take much cam before is screams " you bastard"!
junkcltr
Aug 2, 2019 11:12 PM
92camaroJoe
Aug 13, 2015 06:07 AM
