Gettin' a little bit of hesitation
Old Apr 2, 2001 | 02:33 PM
Steve89GTA's Avatar
Put a new distributor in...car fires up right away! and passed the sniffer with no AIR.
Some things I noticed:
a. Car sounds a little different
b. A little bit of hesitation is evident around 2100 RPM. When it hits 3 it feels like a motorcycle powerband and I get full throtle feel.
Are these symptoms because I didn't get the timing done after the distributor swap. The teeth on the cam/distributor lined up perfectly but I think the distributor assembly may be positioned a little differently than before. Also noticed that the car warms up fast now (but it has been in storage for 4 months)...and this could be a question of old gas...
I want to get the timing done just to make it bang on. Stock for my car is 6deg, should I go higher with my mods??
Thanks!
Steve
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
[This message has been edited by Steve89GTA (edited April 02, 2001).]
Old Apr 2, 2001 | 02:58 PM
Bort62's Avatar
if the Dist houseing is rotated in a differnt direction It will change your Initial Timing.
And if You swapped out dists, even if you makred the position You are probrably off a little bit, Its fairly precise.
Go ahead and time it up and your problem should Go away.
Ill guess that your running a little retarded ( arent we all? )
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Apr 2, 2001 | 07:35 PM
Steve89GTA's Avatar
If I turn the distributor CLOCKWISE, will this adnave my timing or retard it? I'm guessing advance but I'm not sure.
RedLeader289
May 28, 2019 01:47 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
drumstixer
Sep 29, 2015 03:02 PM
Marc Brown
Sep 28, 2015 01:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
