Can someone give me a HP estimate
I have used Desktp Dyno 2K and it says 470@6500 416@5500 thats using the dart file for my heads and everything. I just dont think thats right though. Here's my setup can someone give me an idea of what it should be at the wheels?
350 bored .030
10.3:1 compression
Dart Iron Eagle II's
2.02 1.60
64 cc ported/poliches/gasket matched
1.6 Roller Rockers
Weiand Steal Intake
700 VS Holley Carb
.549/.549 246*/246* @.050
IVO@19* IVC@47* EVO@55* EVC@11*
Lobe Center 108 Overlap 30
Hooker Super Comp Headers
MSD Super Coil
Connected to TH-350
3600 Stall
3.43 gears
Cant think of anything
350 bored .030
10.3:1 compression
2.02 1.60
1.6 Roller Rockers
Weiand Steal Intake
700 VS Holley Carb
MSD Super Coil
Connected to TH-350
3600 Stall
3.43 gears
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
I would say you program is about right. I hope you don't plan on driving that thing much on the street because your drivability will be terrible.
I'd have to agree with Zippy, I think 470 is a little higher. It is possible you might be seeing high numbers at high rpm, I asume the cam can get to 6500 maybe even 7000 assuming you have enough air coming in, but 410 - 440 sounds like a good number to me and aroudn 420 torque. Hey, don't worry about how much power it has, worry about your times
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
87 GTA 350 L98
Fastest ET's
Car: 2002 SOM z28
<font face="Verdana, Arial" size="2">Originally posted by ede:
damn you must have one hell of an engine builder
</font>
</font>
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
I wouldn't be surprised if he's making that much power, if the engine can take the 6500 RPMs. Your cam's duration @ .050" is extremaly high at 246 degrees. This engine will suck down low but scream in the higher RPMs. I'd suggest building a tough bottom end to take the high RPM horsepower. This engine will probably be real tough to drive anywhere else than the drag strip.
Jason
Jason
Linson
Oct 1, 2015 09:50 PM
