car cutting out at around 5000 rpm any ideas?
Old Apr 2, 2001 | 08:34 PM
bad camaro RS's Avatar
ive got the 6aL and msd timming retard box this jus started recently and it seems when it cuts out my tach jumps all around "kinda of like a short" any ideas?
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old Apr 2, 2001 | 10:42 PM
KW87GTA's Avatar
I'm not totally sure if I am reading you right, but if you say you put in an MSD and now when the tach goes all the way it just drops or pops around this is common. MSD actually makes a tach compensation box that fixes this. It's easy to hook up and cost about 40 bucks. I'm sorry but I don't know the part number or exact name. Call Summit and I am sure they can set you up with the right part.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old Apr 3, 2001 | 05:34 AM
no ive had the msd a while my car is acutally cutting out "missing" around 5000rpm but everything below that is fine later
4" mufflex system
Old Apr 3, 2001 | 11:13 AM
JPrevost's Avatar
Car: 91 Red Sled
Check your fuel filter. Could be really dirty and not flowing as much fuel. Also might want to check for arc around the distrib. Another test would be to run the car up to where it misses and try and keep it up there for a couple seconds then pull the plugs, if it's a wet black then it isn't the fuel delivery problem but definatly a spark problem, if it's dry black then it's a fuel delivery problem.
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
mx127
Aug 10, 2015 08:13 AM
Sherpajames
Aug 7, 2015 06:56 PM
