WHATS UP W/ MY 92 Z28???
Old Apr 3, 2001 | 06:47 PM
305-Jive's Avatar
i just got it tuned up (plugs, wires, fuel injectors cleaned the whole nine yards)
and today i started it and had it in neutral but then the engine dies. i started it again and keep my foot on the gas so the engine wont die for 5 minutes but as soon as my foot comes off the gas it dies again.
this happened to me once before but it went away after i tuned my car up BUT NOW ITS BACK!!!
does anyone have an idea whats wrong??? could it have something to do with my bullet i put in place of my muffler because this prob started about 2 weeks after my exhaust mod.
1992 25th Anniversary Z/28
LB9 5Speed
Ram Air, K&N Air Filters, TB Coolant Bypass, B&M Ripper, Dynomax Race bullet, Most free mods
Old Apr 3, 2001 | 09:22 PM
305-Jive's Avatar
HELP!!!!!!!!!
Old Apr 3, 2001 | 09:42 PM
ZDADDY92's Avatar
Check your Idle Air Control(IAC) Sensor. Try to adjust it to see if you get anything from it, or check and see if it is bad. I have never had this problem, so I am not for sure, but this could be a possibility. Hope this helps......
92 Z-28
305 -5speed
160 thermo.
K&N Air Filters
B&M Ripper
14.7 @ 96mph
Old Apr 4, 2001 | 12:04 AM
rezinn's Avatar
Check for a vacuum leak, happened to me once. If your vacuum lines are really stiff, you might want to replace them just for the hell of it.
Old Apr 4, 2001 | 12:07 AM
The ODB's Avatar
how did you clean your injectors?
Old Apr 4, 2001 | 12:19 AM
BTS88IROC's Avatar
Does sound like it could be a vacuum leak. Have you checked to see if you have any?(propane method?) Or checked vacuum pressure? Also how is your fuel pressure? Just a couple things to check.
Old Apr 4, 2001 | 12:21 PM
305-Jive's Avatar
ODB i didnt do it i had the shop do it
thanks for the ideas guys ill have to check it out. the wierd thing is when it gets warmed up to 200* it runs fine but below that it will stall if i dont keep my foot on the gas.
ANYONE ELSE HAVE IDEAS OR HAD THIS PROBLEM???
Old Apr 4, 2001 | 07:26 PM
The ODB's Avatar
take it back to the shop and tell them it's messed up now.
Old Sep 25, 2002 | 11:45 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
SOUNDS LIKE A F**ED UP IAC. IT MAKES SENSE TRY ADJUSTING OR REPLACING.
Old Sep 25, 2002 | 01:43 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Definitely NOT a vacuum leak. A vacuum leak on a SD car does absolutely nothing except raise the idle speed.
Most likely cause is a dead or dirty IAC as has already been suggested. If it will idle fine with your foot on the gas, etc and is otherwise running fine, the IAC is an easy target.
Old Sep 25, 2002 | 01:46 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
This post is from April...
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
