ZZ3 intake on L69
Old Jun 13, 2004 | 10:44 PM
David M's Avatar
Car: '84 Z28
Engine: L69
ZZ3 intake on L69
The intake manifold on my '84 L69 is cracked and needs to be replaced. I've done a search and can't find much info on this manifold. Has anybody installed a ZZ3 intake on their 305? Good results?
Old Jun 14, 2004 | 07:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have a ZZ4 one; same thing AFAIK.
Works fine.
Old Jun 14, 2004 | 04:14 PM
YenkoZL1's Avatar
Car: 1991 RS Camaro
Engine: Custom Built 327
Transmission: Tremec 5-speed
Um... the ZZ4 intake will not work on a 305ci because the ZZ4 intake has the vortec style runners to match up with the heads. Vortec head has LT1 style runners and the 305 heads dont.
Old Jun 14, 2004 | 04:34 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
ZZ4 does not have Vortec heads, it has Aluminum L98 heads from a Corvette. The intake will work fine and give you a little boost in power.
Old Jun 14, 2004 | 04:42 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Does the ZZ3 intake have any hood clearance problems??
Auggie
Old Jun 14, 2004 | 05:55 PM
David M's Avatar
Car: '84 Z28
Engine: L69
No clearance problems. The H.O. 350 instruction manual from GM shows the '87 Sport Coupe with a stock hood.
Old Jun 14, 2004 | 06:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It sets the carb up about a half inch higher than the LG4/L69 intake. Makes the PCV tube from the valve cover to the air cleaner a stretch, and the air cleaner stud had better not stick too high above the lid (shouldn't be a problem if it's stock).
Old Jun 14, 2004 | 06:19 PM
Auggie's Avatar
Thank you, thank you.
Auggie
Old Jun 14, 2004 | 09:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Glad to hear that..... guess I better quit driving it, eh?
Seems to fit my 305 and its 69 model 186 heads just fine. Direct bolt-up. Fits perfect along with the stock carb and HO air cleaner.
Old Jun 14, 2004 | 10:50 PM
five7kid's Avatar
Yep, I'd better stop, too.
Old Jun 15, 2004 | 05:48 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Shame on you two
Old Jun 15, 2004 | 09:54 AM
Auggie's Avatar
Five7kid, that A/C "V" belt looks awful close to that rad. hose. I have a bracket to hold the hose up and away from that belt. See pic.
Auggie
Old Jun 15, 2004 | 12:11 PM
five7kid's Avatar
The hose is for the '86 application. The AC bracket holds it away from the moving parts. There's about an inch there. It's never been touched.
Old Jun 15, 2004 | 01:31 PM
Engine: 305-4v
Auggie
That aircleaner is deeper than a HO unit. Where did you find it?
Old Jun 15, 2004 | 03:01 PM
Auggie's Avatar
Sitting Bull, my orignal eng. was a L69 and came with the duel snorkel A/C, but I changed my carb to a 750 cfm and the eng. to a 355 so I sold the A/C to some guy in Wis. fo $100. A buddy of mine had a friend that worked in a tin shop. We started with a dropbase open element A/C and he made the housing out of alum. The element is a K&N 14" x 3" and I used the orignal inlets that came with the car. I had to use the dropbase for hood clearance.
Auggie
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
