Pro Topline 50cc heads and 305's
Old Jun 14, 2004 | 04:44 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
anyone tried that out? for $600pr, that ain't bad, and it'd raise compression too.
maybe if my 305 lasts longer than i expect, and i dont do a 406, i'll have to try this out..
they also have a stock replacement for the 305 too
Old Jun 14, 2004 | 07:46 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Cute but the valves are too big and the valve spacing is all wrong for a stock bore 305.
These are racing heads.
Old Jun 14, 2004 | 07:59 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yes but we have the technology to cure that problem. The big question would be would it be worth it.
Old Jun 14, 2004 | 09:14 PM
onebinky's Avatar
IIRC it will raise the compression to about 10.6:1 on cast iron heads. Be ready to run the race gas
I was looking into the same thing, but couldn't risk the high compression and the risk of valve/bore interference with the 2.02 valves. I ended up going with the s/r torquer 305's, seem to be decent so far.
If you end up doing it, post back the results please.
Old Jun 15, 2004 | 01:47 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
heck no...i got some 113 heads complete for $100.
maybe one day.
Old Jun 15, 2004 | 01:59 PM
onebinky's Avatar
That's a good deal Those are the aluminum vette heads, aren't they?
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
