I confused myself! :) Position of rotor relative to #1 cap term for advance?
Old Apr 3, 2001 | 11:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Say I've set up, oh, for example, a 2.8 engine, and am doing the timing. I've confused myself! Is this right:
#1 cyl's at TDC. For advance, the rotor should be "after" (clockwise to) the #1 terminal on the distributor cap, right? The firing order is 1-2-3-4-5-6, so the rotor should be between 1 & 2...?
Thanks! I was sure, but I keep thinking about it, and now I'm not.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 3, 2001 | 02:28 PM
Damon's Avatar
Yes, that's right. Just make sure you know which way your rotor turns!
You sure about that firing order?
[This message has been edited by Damon (edited April 03, 2001).]
Old Apr 3, 2001 | 05:38 PM
ede's Avatar
ede
yep 123456, gm made it real simple for us guys with a v6
ICON Motorsports
1st & 3rd
Old Apr 3, 2001 | 05:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Gotta change the code on my luggage
ICON Motorsports
Old Apr 4, 2001 | 04:33 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
<font face="Verdana, Arial" size="2">Originally posted by TomP:
</font>
Easiest way is to set the damper for the amount of advance you want and then simply align the rotor with the #1 distributor terminal.
That way you don't have to remember which was the rotor turns.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Apr 5, 2001 | 10:23 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Really?? Someone told me that wouldn't work! Great! So say I wanted 10 deg advance. The balancer would point to 10, then I'd line up the rotor and #1 cap terminal? Sweet! I'll do that next time, definately- thanks!
Infested
May 22, 2018 11:56 PM
Thornburg
Aug 30, 2015 08:05 AM
86IROC112
Aug 17, 2015 07:57 PM
Thirim
Aug 13, 2015 03:09 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
