Im scared :-)
Old Apr 4, 2001 | 09:38 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Im scared :-)
Not scared, just wanted to get attention for people to read my post. SOMETHING IS WRONG!!!
It started with a vibration under higher torgue like accelerating (any rate of acceleration), It was normal at highway cruising at any RPM.
Then this noise started where it sounds like someone droppin something in a tin pan...but at a constant rate, not like something bouncing around randomly....
And the vibration went away, the sound seems to be coming from the area of the Belts, Water Pump, Radiator area, doesnt sound to be internal of the engine itself.
When I shut the car off, you hear almost like a ball spinning from centrifugal force in a tin can or something like that and stops maybe 5 seconds after the engine has stopped. So far twice I have felt the vibration kinda bad while accelerating.....
Oil pressure is fine, Battery charging fine, power steering fine, car suffers no power loss although I have not really opened it up since it started.
What the h*** could it be?
1986 Trans Am, T-Top, 305 TPI, Flowmaster 80 series. Much more to come in July.
[*]Sound System: Dual 12" Ground Zero Nuclear Series 900 watt RMS subs in custom box made to fit the rear well, Only 500 watts running them though, Pioneer Head Unit and Rockford Fosgate wiring.
AOL screen name= madbiker1
Old Apr 4, 2001 | 10:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like the inertia ring on your harmonic balancer has broken entirely free of the blob of spooge that ordinarily connects it weakly to the actual engine... it could launch itself through the radiator, or who knows what. You need to get it taken care of ASAP!!
Don't try to set your timing right now. The timing mark is adrift.
ICON Motorsports
Old Apr 4, 2001 | 11:15 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Yes that would be my guess also. My idiot firends 86 vette did this. Unfortunaltely, he kept driving it (bump shifting @ 5500rpm with a stock L98) until it shattered into 3 pieces.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
Old Apr 5, 2001 | 05:46 AM
86FyrBrd's Avatar
So I guess nmy next question is........how much is it gonna cost me to get that fixed....sounds expensive.
Old Apr 5, 2001 | 10:29 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well a new harmonic balancer will cost ya about $60, but you have to remove everything in front of it to get it off. This means crank pulley and fan at the very least, but I think just to get a wrench i nthere the radiator has to come out. Then you'll need a balancer puller which you can rent from Autozone for $15. You get the 15 bux back when you return the puller.
1983 Firebird
TH700R4 Auto
Small Block 400
Old Apr 5, 2001 | 11:01 AM
SUPER-SPORT-CHEVY's Avatar
Could be the balancer but it could be as simple as the fan clutch bearings are gone!
Gl
Old Apr 5, 2001 | 11:47 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
If it is the balancer, you can do it on your own for cheap. When I changed the timing chain on my motor I had the balancer off. You shouldn't have to take the radiator or the fans out. Just take the serpentine belt off and then the balancer pulley. Rent the balancer puller tool and the install tool. Get yourself a new balancer and just swap them over and put the pulley and belt back on. You can probably do it in an hour or two since it's your first time.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
New2Chevy
Sep 28, 2015 12:35 AM
ChevyLuva3
Dec 3, 2001 05:41 PM
88greyiroc
Jul 25, 2001 11:32 AM
green_is
Apr 9, 2001 03:09 PM
3504mula
Feb 8, 2001 10:37 AM
