should i be scared away by mileage
Old Apr 8, 2001 | 03:09 PM
green_is's Avatar
should i be scared away by mileage. say i saw a camaro or something with a V8. the only thing is that it has like 120,000 miles or higher. at what point should i draw the line.
Old Apr 8, 2001 | 03:21 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
That's where your personal preference comes in to play. It depends, how much are you willing to do and spend to get this car the way you want it?? There are thirdgens out there that were taken care of religiously with 200k on them and look and run great. Then there are those with 60k out there that look like they have been through hell and back. Do your research, ask for maintenance paperwork, "interview" the seller, find out as much as you can about the car regardless of the mileage and make your decision from there. Last but not least, if the seller is someone who frequents this place, for the most part I'd say that the car is pretty well taken care of. Good luck.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 8, 2001 | 03:26 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Mileage don't mean squat to me. Most of the "wear out" items are usually replaceable w/ high performance parts, and are usually replaced before the stock piece wears out anyway.
Like Kevin said, it depends on how it was taken care of. My car has 160,000+ miles on it, and it looks better than some of the 50,000 mile cars out there. Plus you can usually get a better deal on high miler cars.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 8, 2001 | 09:00 PM
SUPER-SPORT-CHEVY's Avatar
120k if well mantained or halfway mantained should still run very good. I had a 305 that had 300k on it it used a qt of oil between iol changes but i got my bang for the buck.
A good sign if the car is running right is to start it cold and see if its puffing out blue smoke then drive the car when its warmed up and see if the transmition is slipping "pop it one". In general a car with 120k on it should be in proper running order just make sure that every thing is sound take it to a mechanic before you buy it and check the blue book price out at www.kbb.com/ to make sure its not to high. Gl SSC!
Old Apr 8, 2001 | 09:18 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
My 1989 Iroc has 235000 miles on it with the orignal 305 tpi and it runs and looks better than when I bought it. yes it does matter on how much people take care of there cars, mine sees a oil change at every 2000 miles no later, hell oil is cheap, cheaper than replacing broken engine parts. I my opinion it is up to how the car runs, looks and drives, and then it is up to you if you want it or not.
Old Apr 8, 2001 | 10:01 PM
LottaBallsCamaro's Avatar
Get anything you want, chances are you'll wreck it before it commits suicide.
We are the future, the 21st. century dislexyic, glue sniffing, cyber *****, with homicidal minds and handguns.
Old Apr 9, 2001 | 01:47 PM
Bort62's Avatar
My Camaro hah 148K when I got it, and 155K now.
It runs perfectly, And looks Almost new.
Look at the previous owners other cars, To get an idea of How well he took care of it.
and check oil pressure, get a Buddy who knows about cars to take a look at it for you.
How well it wsa maintained will be the key here.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Apr 9, 2001 | 03:09 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Alright, lotsa personal experience good w/ high milage cars, heres one not so good. My car was a piece of sh*t. I bought it 2 and a half years ago, rebuilt the trans, rear end, and several top parts of the engine. However, I got it cheap! $3000 in a running condition. I knew it was a project car! Everything I fix on it is a "upgrade". Just get a look at it, talk w/ the guy, and decide how you want to play it. Do you want something you never have to get your hands dirty w/, or something you can't wait to get your hands dirty on.
Good luck w/ it either way!
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
SLP 1 3/4" headers, 3" cat back (stock cat )MSD ignition. MSD Blaster SS coil. More soon when funds are avail...
plm99
Southern California Area
Nov 16, 2015 05:21 PM
sammy52401
Nov 11, 2015 07:20 PM
bjpotter
Oct 15, 2015 11:07 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
New2Chevy
Sep 28, 2015 12:35 AM
