Brand of filters???
Old Mar 27, 2001 | 04:21 PM
86blkIrocz's Avatar
Brand of filters???
Getting ready to bring the car out of storage and I'm going to be doing some work before she hits the road. I'm going to change oil/oil filter, trany fluid/filter, fuel filter, and dif fluid. What are the best filters to buy for each. I use mobil 1 filter and oil first off. But this will be my first time changing the rest what brands of filters and fluids are the best? One more thing last year I changed my antifreeze to the red 100,000 mile stuff being that I have to change the thermostat should I change the antifreeze back to the green stuff? Any info would help alot thanks in advance.
David Higgins
1986 Black Iroc-Z
305 TPI
Edelbrock Cat-Back
K&N Air Filters
Old Mar 27, 2001 | 04:32 PM
82camaro's Avatar
Car: 82 camaro SC
The red stuff will work fine, and actually transfer heat better than the green. My opinion on filters is Baldwin, which do make Amsoil filters(I got a hold of a Baldwin exec finally). However, everybody has an opinion of filters and fluids. A better question to ask on this board is which filter and fluid brands to stay away from. For example, Fram filters are really bad.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 27, 2001 | 06:01 PM
Steves ZZ5's Avatar
I second the FRAM oil filter comment....Bad...Bad....Stay away.
take one apart sometime and look at it. It might frighten you a bit.
I use the A/C PF35 filter. Good construction and many pleats. The Mobil 1 filters are far superior being that they use a "synthetic" filtering media and have multi-layer micron filtering capabilities (filters the bigger chunks first, and then the inner portion filters smaller particles, and so on and so on). They're $9 around me, so I stick with the PF35 for now since I change my oil frequently. Can never change your oil too often.
There are going to be soo many different opinions, so i'm ready for challenges.
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
Old Apr 3, 2001 | 06:32 PM
Anniversary-SS-man's Avatar
I use Mobil 1 filters all the time. I would run it for oil, I use AC for fuel filter, and anyone's for the trans filter. For the antifreeze, if you mean Dexcool, it is better than the older green stuff; leave the red stuff in.
  • 1997 30th Anniversary SS LT4 #74 with K&N, white gage faces, and Hotchkis shock tower brace - In process: SFC's
  • 1996 Corvette Grand Sport LT4 #509 with K&N, Flowmaster exhaust, Hypertech power programmer, and Baer slotted/cross-drilled brakes - In process: SLP throttle body and 1-3/4" headers, AFR heads, 4.10 gears, custom Panasonic/Alpine/Audio Control audio/ADS system
  • 2000 Chevy TrailBlazer
Old Apr 3, 2001 | 06:49 PM
ede's Avatar
ede
i use ac or wix filters
ICON Motorsports
1st & 3rd
Old Apr 3, 2001 | 09:49 PM
superz's Avatar
woah i didn't know that fram filters were bad, what is wrong with them?
86 IROC-Z
40,000 miles!!
305 TPI
gutted maf/airbox
k&n filters
manual cooling fan switch
headers, no cat, cat back flowmaster
700R4 tranny
shift kit
manual converter switch
BF Goodrich radial TAs
3.23 gears
georgous car repainted by my dad and assembled by me
FASTER THAN YOU THINK FOR A "STOCK" 305 hehe.
Old Apr 4, 2001 | 06:02 AM
Steves ZZ5's Avatar
Well...Tear one apart sometime and check it out. The construction is quite poor. The internal end cap is made of flimsey filter media, and GLUED in place. the surface area seems to be quite alot smaller than an A/C equivalent.
Supposedly, there have been lawsuits against Allied Signal (makers of FRAM) because of catastrophic engine failure due to filter failure. I heard that Allied Signal scoffs at such lawsuits because in a court of law it's very difficult to determine an engine has failed due to filter failure. Hell, they can just claim that when the engine blew, that the failed component pieces traveled to the filter and THEN destroyed the filter, not the other way around. FRAM is the most popular filter on the market, it's inexpensive which sells it, and it's heavily advertised....They don't sweat lawsuits when they make millions a year. Stick with an A/C oil filter for close to the same price, and have piece of mind.
The Road Warrior
Old Apr 4, 2001 | 06:14 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
I can say that mobil 1 is the only filter I use, but what are your thoughts on the purolator ones, I just changed the oil and filter on my friends 82z and used a purolator one... OHHH before the purolator one we had a fram/allied signal one, I dont know WHAT THE HELL happened but the thing just like fell apart when I initially started the car up, 5 FREEKIN QUARTS OF OIL ALL OVER THE STREET!!!!!!!!!! sooo after a trip to the auto parts store, some kittie litter stuff, a new filter and 5 more quarts everything is fine... got the money back too =] MORAL: NEVER GET FRAM PRODUCTS FOR YOU CAR!!
Old Apr 4, 2001 | 10:23 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I used to use Fram, never had a problem... then I found that one website- you guys know the one, right? Oh, man, I hate slow web servers... this was the last link I had for it, but I don't know if it works: http://members.nbci.com/minimopar/oilfilterstudy.html
Anyway, since then, I use Purolator or AC. Those came out the best in that study. Too bad, I liked that nuclear orange color of the Frams!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 4, 2001 | 10:56 AM
MINN IROC-Z's Avatar
Car: 1988 IROC Z
I have used K/N oil filters and air filter and have never had a problem with any of thier stuff. I use then in conjuction with Mobil 1 oils but have never tried Mobil 1 filters. I might though because they more available without having to mail order all the time. Just my two cents worth.
Old Apr 5, 2001 | 09:00 AM
CamaroZ_85's Avatar
i sell purolator filters and they come w/ a little display showing cutaways of 3 filters...the "other" brand (fram) which looks like a folded up paere towel in a pepsi can, the regular purolator filters which are far better looking than the fram, and the purolator pure one (it's blue and the part number starts wiht "PL") and they have a lot of filter paper inside them, they look pretty well built. i would use the pure one, but I go with the AC Delco because they are equal quality if not better...the purolator trans filter seem to be well built also
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Apr 5, 2001 | 09:17 AM
jobryan26's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TomP:
</font>
HOLY ****! This is all news to me. Hey someone needs to put this info in the Tech Area like with the mods stuff! Thanks Tom I'm ripping that oil filter off my car today and changing my oil. I'm serious about posting it in the Tech Area tho people need to know this stuff!
'87 Trans Am:
(Engine)
305 TPI
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Kenwood Excelon
Old Apr 5, 2001 | 09:50 AM
Steves ZZ5's Avatar
I agree with you Jobryan....Definately good for a tech article, or at least in the "vendor Review" board or "Aftermarket Product Review" board. Anyone wanna carry the ball??
My two choices for what I would buy:
1)A/C PF35......Best bang for the buck.
2)Mobil 1.....A little pricey, but probably best filtering capabilities.
Old Apr 5, 2001 | 11:54 AM
86blkIrocz's Avatar
Thanks for all the info guys next week I'll bring her out of stoage and change all the fluids.
David Higgins
1986 Black Iroc-Z
305 TPI
Edelbrock Cat-Back
K&N Air Filters
Old Feb 24, 2009 | 11:47 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Brand of filters???
I agree with this choice but add K&N Oil Filter.
Old Feb 25, 2009 | 08:21 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I like the Wix (or Carquest brand) filters as an easy replacement. There are specialty, better filters out there - but may be hard to find in a retail store.
On thing I will advise is to get a longer (higher capacity) filter as it not only increases oil capacity, but also has more filter area. Typically a few quarters more than a nomral SBC one.
Hotrodboba400
Dec 10, 2019 07:07 PM
earlpote
Sep 12, 2015 11:55 AM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
