felpro 1094s with zz4 heads on l03
Old Jun 17, 2004 | 09:02 PM
Formula305FI's Avatar
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
well im swapping the heads this week, its my bday weekend and i decided to take the week of from work and do this.. can i use these gaskets the 1094s with the aluminum zz4s? the zz4s have been milled for flatness, and i can clean the block deck pretty well... I know i would need to coat the gaskets no biggie, so can it be done, and i not run into problems 1-5k down the road?
Old Jun 18, 2004 | 12:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 1094's are not intended for aluminum heads, if I recall correctly.
Old Jun 18, 2004 | 01:14 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Not 100% sure, but i think those are among the lines that Fel-Pro designed to have good sealing ability, with the ability to be used with aluminum heads. However, i do recall reading that they have a rather small compressed size, under .020" or maybe even .015" so keep an eye on compression.
Also, i don't think they need any forms of coating.
Old Jun 18, 2004 | 06:07 AM
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
no it says for use with aluminum or iron heads, just didnt know if i was going to have a problem with them on a 305 ya know
Old Jun 18, 2004 | 10:55 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
calculate the compression.
Old Jun 18, 2004 | 02:12 PM
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
i think im going to go with the safe route of the 8510s the economy head gaskets @least they wont leak, lol... Speaking of those gaskets... Will I have any problems running the felpros with the 1.94 valves and a 305 head gasket??? This is my next concern... Im ready to put heads on and im done to the gaskets... Should I use the felpro 305 gaskets 8510s, or get the 7733 350 head gaskets???? I just picked up the 8510s... I think the thickness on them is .32.... Where as the 7733s are .41... But i dont know if the 305 will interfear with the 1.94 valves.
Old Jun 18, 2004 | 08:02 PM
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
TTT
Old Jun 19, 2004 | 12:28 AM
five7kid's Avatar
The gaskets don't go inside the chamber, so they won't be a problem with 1.94" valves.
I don't know specifics about the gaskets you got, but they should be just fine.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
