vaccum leak
Old Jun 20, 2004 | 09:38 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
vaccum leak
i have a vaccum leak. pretty sure anyways. and i can't find where it is. i have sprayed brake cleaner in every area possible and i get no reaction. any ideas?
Old Jun 20, 2004 | 09:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked the condition of your vacuum lines and hoses?
Old Jun 20, 2004 | 10:00 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
How is the PCV valve? PCV is a controlled leak remember.
Old Jun 20, 2004 | 10:01 PM
trueburton's Avatar
i have checked and replaced the iffy lookin ones
Old Jun 20, 2004 | 10:03 PM
trueburton's Avatar
what do you look for on the PCV valves?
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the non iffy ones as well!!!!
Old Jun 20, 2004 | 10:05 PM
trueburton's Avatar
well i checked tehm all but only replaced teh iffy ones
Old Jun 20, 2004 | 10:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
shake the PCV valve. you should hear it rattle.
Old Jun 20, 2004 | 11:48 PM
onebinky's Avatar
You should only be able to blow through it one way as well. The best part of doing that test is when you get the nasty old oil taste in your mouth
Might want to replace it anyways. Should be replaced approx. every other oil change, and they are only a few bux.
What kind of symptoms are you getting to where you think you have a vacuum leak?
Oh, stuck open EGR is the other vacuum leak that is harder to diagnose on the TPI, I believe it's in the open on most other cars. If you press in slowly on the diaphram you should notice the idle getting worse and worse until it dies. If you have a vacuum pump you could also feed it vacuum gradually to 15" and note the change in idle.
Old Jun 21, 2004 | 07:34 PM
trueburton's Avatar
the engine revs once in awhile. varies between 1000-1500 usually not any higher. If i spray brake cleaner near the TB and runner on the pass. side it revs up like to 1400. can't pin point the exact location thaough. I also thought it might be the IAC.
Old Jun 21, 2004 | 07:38 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I always chuckle at "vacuum leak" whenver I see it
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the bolts on the TB and that runner to make sure they are tight.
Old Jun 21, 2004 | 07:45 PM
trueburton's Avatar
i did remove the plenum a while back but used the old gaskets when i put it back together. This is prolly bad right? should i pick up some runner and TB gaskets?
Old Jun 21, 2004 | 08:07 PM
onebinky's Avatar
Yes, it's never good to reuse paper gaskets. Especially if they tear or get mixed up.
Get a new upper intake gasket set, shouldn't be to much. The engine shouldn't rev at all when you spray the ether on it.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
