code 13 and car misses
Old Mar 30, 2001 | 08:16 PM
89transam350's Avatar
I just switched to a replacement crate motor for a 91-93 caprice tbi and put my TPI on it. I have set the timing twice and it keeps jumping back to about 14 and it misses really bad at about 3500 rpm and pings when it changes gears and when i first get on it. I can't seem to find out what the problem is also my tach jumps around every where under throttle.
THANKS
[This message has been edited by 89transam350 (edited April 05, 2001).]
Old Mar 30, 2001 | 09:04 PM
ttt
Old Mar 30, 2001 | 10:06 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
code 13 is an open oxygen sensor circuit. its probably junk but check to make sure the wiring is good.
Old Mar 31, 2001 | 08:13 PM
some has got to know i have 4 days off and need to work on it
Old Apr 5, 2001 | 07:38 PM
ttt
Old Apr 6, 2001 | 12:01 AM
someone please help me out
Old Apr 6, 2001 | 09:55 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Well, I'll throw it back up for ya, but I have no ideas, I'd say try and fix the o2 sensor problem, and go from there. Does that have an ESC system on it, spark knock sensor good? It seems to me that if it had really bad knock, the ESC should start heavily retarding timing. Otherwise wait ti;; one of the gurus gets in here, or make a new topic ATTN:Vader/GM Tech/Etc that should get their attention
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
SLP 1 3/4" headers, 3" cat back (stock cat )MSD ignition. MSD Blaster SS coil. More soon when funds are avail...
Old Apr 7, 2001 | 11:26 PM
i moved around the wires in the back of the dist. and so far it hasn't done it again
THANKS
[This message has been edited by 89transam350 (edited April 07, 2001).]
[This message has been edited by 89transam350 (edited April 08, 2001).]
Old Apr 8, 2001 | 12:18 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Check your timing, the wires are in the right order, replace the O2 sensor, make sure all the wires are pluged in for the ESC and umm dont be a **** =)
Kat
hectre13
Dec 11, 2023 08:14 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mizz0313
Aug 12, 2015 06:45 AM
apie2546
Aug 10, 2015 05:43 PM
