airdam????
Old Jan 28, 2001 | 06:02 PM
burnoutrpm's Avatar
airdam????
i have a question? what is the part# for a new g.m. airdam? i recently broke off part of mine and need a new one, i saw on this site people have probs with that part and they listed what the new part # was please email me with the new part#
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 and a 600 edlebrock manual choke.
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Old Jan 28, 2001 | 06:51 PM
ede's Avatar
ede
just go to a deal they'll figure out the PN for you
ICON Motorsports
1st & 3rd
Old Jan 28, 2001 | 07:19 PM
burnoutrpm's Avatar
my friend tried that and they SAID they coulnt get it any more?
Old Jan 28, 2001 | 07:28 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
burnout, i just bought one off ebay new in box and i have seen more of them on ebay, i know there is one for sale on there now new in box
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
March Underdrive Pulleys
otherwise stock 5.0TPI
700r4, 9 bolt 3.23 g92 axle, 4 wh. disc brks.
Old Jan 28, 2001 | 07:37 PM
burnoutrpm's Avatar
how much you get it for?
Old Jan 28, 2001 | 09:28 PM
Vader's Avatar
Burn,
Red Green makes his own, improved version of the lower air deflector. Mysteriously enough, there is no duct tape involved!
If you want the OEM part numbers, they are as follows:
10020322 - Deflector, Panel Center Air. Fills the lower radiator support and seals to the lower air deflector, $29.80 list.
10017673 - Deflector, Radiator Lower Air. Mounts to the lower fascia and deflects air upward to the radiator. This is the one most of us break off, $23.05 list, in any color you want as long as it's black.
Both are still listed as active parts - e.g. NOT obsolete.
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
[This message has been edited by Vader (edited January 28, 2001).]
Old Jan 28, 2001 | 09:46 PM
burnoutrpm's Avatar
hey vader thanks always can count on the moderator for a excellent response! thanks again!
Old Jan 28, 2001 | 11:47 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
burnout, i gave 25 for it but sometimes people tend to run up prices on ebay especially if they bid days ahead of the closing. i really like that home made version in the pic that vader posted. is there any how tos as to how that was built.
Old Jan 30, 2001 | 06:30 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Since the 86's are readily available I can't imagine discontinuing the 89's. I would go to a dealer though because on the 86 alone their are 3 separate part #'s available for the strip that Vader shows. Well, let me put it another way. The air dam pieces are called "deflectors". Their are 3 available deflectors.
Nose Cone Piece
Strip across front (like vader shows)
Piece that mounts to radiator.
Then, on the strip that goes across the front their are 3 different part numbers available.
Point being, there is a lot of margin for error of getting the wrong part.
Old Apr 3, 2001 | 03:18 PM
T/A Man's Avatar
Service Bulletin from All Data
Front Air Deflector/Engine Overheat (New Air Deflector)
Bulletin Number: 88-6-74
Reference Number: 731023R
Publish Date: 9/88
Subject: FRONT AIR DEFLECTOR/ENGINE OVERHEAT (NEW AIR DEFLECTOR)
Models
Affected: 1985-88 FIREBIRD TRANS AM/GTA
"This bulletin supersedes Bulletin 87-6(Gasoline)-49. Date 7/1/87. This bulletin has been revised due to a new air deflector part number and to add the 1988 model year."
Effective start of production, 1989 the lower air deflector will consist of three pieces rather than one in regular production. For service on the subject vehicles the service deflector will likewise consist of three pieces rather than one.
For service, install the revised deflector per instructions provided in the service kit. The part number for the service kit is 12395557.
Parts are currently available from GMSPO.
This part set costs $37.00 and is currently available at any Pontiac Dealer.
Old Apr 3, 2001 | 04:11 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Have you tried an auto wrecker/recycler?
Old Apr 3, 2001 | 04:44 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
Have you tried an auto wrecker/recycler?</font>
That's what I'm screamin'! Hell, my airdam is off a Ford Ranger Pickup truck from a salvage yard ....and cut to size!!
Old Apr 7, 2001 | 08:18 PM
T/A Man's Avatar
I installed the new revised airdam which was mentioned above in my last 2 cents was finally installed this morning. It fit beautiflly and completely fixed my over heating problem. My engine's temp is rock solid at 198 degrees at all speeds. I am one happy camper!
Old Apr 8, 2001 | 01:23 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
I am holding a NEW GM Radiator air deflector in my hands right now. Black as coal. I just got it from Third Gen Resource for $25 plus shipping. It's GM part number 14083929 is stamped right on it. This is for my '89 IROC. It's held on with 6 bolts under the radiator and feeds fresh air to the radiator. It's the darn plastic piece we scrape on speedbumps and high curbs and such!!
Hope this is the part your talking about!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
[This message has been edited by Phil87IROC (edited April 07, 2001).]
Old Apr 8, 2001 | 09:08 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Not available? I bought this one three months ago: Airdam
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
--&gt;14.97 @ 94.9 MPH&lt;--
'97 Bonneville SSE
Old Jul 29, 2008 | 05:22 PM
ikeepitreelz's Avatar
Car: 1988 gta-
Engine: 383 tpi
Transmission: 700 r-4
Re: airdam????
So what is THIS airdamn? which one did GTA'S come with ..? confused
Old Jul 29, 2008 | 05:27 PM
Car: 1988 gta-
Engine: 383 tpi
Re: airdam????
yeah i know this post is old but iam posting just in case someone does a search, i found this helpful link if not confusing.
http://www.yearone.com/serverfiles/h...0AB222&Style=2
Old Jul 22, 2011 | 02:12 PM
tweed's Avatar
Re: airdam????
Hey guys i need that lower air deflector for my 86 trans am to.anyone know where i can get one?thanks.
Old Jul 22, 2011 | 02:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: airdam????
Welcome to TGO, tweed. Check the site below:
http://www.moderndaymuscle.com/exterior4?b=1
JamesC
Old Jul 22, 2011 | 03:27 PM
tweed's Avatar
Re: airdam????
thanks for the help,just one more question.the deflector thingy i need bolts on bottom of radiator with 6 bolts and since the part is gone,i dont know what to look for,any idea?thanks again.
Old Jul 22, 2011 | 08:38 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: airdam????
Lowes actually sells a lot of the GM style body nuts and bolts. Thats where I got the bolts for my new airdam after my old one got taken off.
Old Jul 22, 2011 | 09:47 PM
tweed's Avatar
Re: airdam????
I seen my typo.i have the bolts still so sorry about that.i just need the air deflector so i got some sheet metal and im gonna see if i can make something work for now.
vorgath
Aug 25, 2005 07:49 PM
Cali Z
Sep 6, 2004 06:37 PM
Dante93GTZ
Jun 2, 2003 02:37 PM
Matthew91-Z28
Sep 1, 2002 11:06 AM
Jer82Z28
Jul 4, 2002 08:33 PM
