TV cable adjustment...gone bad
Old Jun 25, 2004 | 09:00 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
ok i have this posted in the tranny forum but i wasn't getting anything there so i'll try here..........
i was reading a post about the TV cable and if the shifts r "loose" to adjust the cable. so i looked in my haynes manual and it sed the same thing. so i did it, i did word for word what the book says (depress and hold metal tap and move the cable housing into slider until it stop against collar. release tab) then it says, for my carb model, to open the throttle all the way and the cable will ratchet through the slider...well i did that but didn't notice any noise from it ratcheting. ok so that all sed...
i took it for a ride up the road and while lightly accelerating it jerks forward from 1st to 2nd and doesn't shift until 3k, and it doesn't seem like it hits OD while going up even the smallest of hills. like it just doesn't seem right . also when i'm on level ground cruising, it's at 1k rpm and when i hit the gas it goes to 2 k then jerks to accelerate. did i really mess something up here to did i do the adjustment wrong??? i was also thinking that MAYBE the tranny had to relearn, but i'm don't think we have cars like that, or do we?
please HELP, BTW 84 TA L69 700-R4
Old Jun 25, 2004 | 09:07 PM
firestorm's Avatar
Car: Firebird
Engine: LG4
Sometimes they wont ratchet back. Press the button and manually move the cable a few clicks foward. Then take a drive and see if its shifting where you want it to be. If not, just adjust some more.
Old Jun 25, 2004 | 09:35 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
http://www.tvmadeez.com/pressure_test/index.html
This site has some great info.
They're good folks to do business with too.
Old Jun 25, 2004 | 09:46 PM
chio987's Avatar
Engine: 305 4bbl HO
when u say manually move it forwards, do u mean pull it out of the slider. (in my case towards the fire wall???) bcuz it's all ready as far in as it would go into the slider
edit: how much would a pressure gauge cost that they use on that site
Old Jun 25, 2004 | 09:57 PM
chio987's Avatar
Engine: 305 4bbl HO
nevermind about the price, searching thier site more, i foud it 30 bucks...not bad
Old Jun 25, 2004 | 09:59 PM
firestorm's Avatar
Car: Firebird
Engine: LG4
Grab the same black part of the cable you did when pulling it back towards the fire wall and push it towards the radiator. You might have to reach in from behind to grab it.
Old Jun 25, 2004 | 10:06 PM
Car: '85 IROC
Engine: LB9
edit: how much would a pressure gauge cost that they use on that site [/B][/QUOTE]
I used a pressure ga from an old oxy acetylene set. It worked.
$30 aint bad tho.
Old Jun 25, 2004 | 10:07 PM
chio987's Avatar
Engine: 305 4bbl HO
ya, it's already as far in towards the rad as it'll go
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
After i did the v6 to v8 swap it took me a few tries to get the tv cable adjusted correctly. Try adjusting it by hand as said above, take it for a drive and see how you like it.
Old Jun 25, 2004 | 10:15 PM
firestorm's Avatar
Car: Firebird
Engine: LG4
If thats the case, better start from scratch.
Press the tab button down and grab cable from behind the bracket and pull it all the way towards the fire wall. Now move the cable slightly towards the radiator. Take it for a spin. If its still shifting high, its too tight. Press the button and move it again slightly more towards the radiator.
Shifting too high means the cable is too tight and has to be moved away from the firewall. If its shifting too soon, then it needs to be pulled towards the firewall.
Old Jun 25, 2004 | 10:19 PM
chio987's Avatar
Engine: 305 4bbl HO
well if that's the case then it being all the way towards the rad then it should be shifting really low rpms. but it's not, it's shifting out of first at 3k
Old Jun 26, 2004 | 11:27 AM
chio987's Avatar
Engine: 305 4bbl HO
ttt
Old Jun 26, 2004 | 10:39 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I have adjusted mine a couple of times this always works for me but requires 2 people. Depress the D shaped button move the slider as far forward (toward the radiator) as possible get someone to sit in the car. Now get them to press the throttle all the way to the floor while the gas is depressed to the floor press the D shaped button and move the slider back toward the firewall until it stops then let go of the D shaped button and your friend may let go of the gas now take it for a drive should be right on almost. Also when sliding it back towards the firewall do not force it slide it smoothly and it will stop if you force it you can make it retract all the way.
Old Jun 26, 2004 | 11:36 PM
chio987's Avatar
Engine: 305 4bbl HO
allrighty zNucleaRz. press the tab, slide it all the way forward (rad), let go of the tab. then buddy floors it, press tab slide it all the back back (firewall)let go of tab then throttle
slide it back nice and easy til it stops...right??
i jusy want to db check to make sure i read it right. i guess part of it would have to do that i'm about to fall asleep
Old Jun 27, 2004 | 01:28 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Yes thats correct sorry it was so long....
Old Jun 27, 2004 | 11:55 AM
chio987's Avatar
Engine: 305 4bbl HO
nooo. it wasn't that it was lond.. it was that i'm was 9/10's asleep and wasn't sure if i was suppose to let go of the tab b4 my buddy hits the gas. but they y i db checked. and i'll be going to do it in a few hours and i'll let ya know if it works.
and thanks
Old Jun 27, 2004 | 12:23 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
I've read that you should not use the pedal to adjust the TV cable because it is very inaccurate compared to manually opening the throttle with your hand. Doing so might cause the TV cable to become incorrectly positioned (not that it matters now anyway, though).
Old Jun 27, 2004 | 02:01 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Adjusting by hand all depends on how well your throttle cable is adjusted. If your throttle cable is not adjusted correctly and you set it by hand it will cause early sloppy shifts. Adjusting by the gas pedal allows it to shift at max rpm when the pedal is depressed instead of when the carburetor is fully open. Not sure this makes any sense or not.
Old Jun 27, 2004 | 04:49 PM
Nate86's Avatar
Engine: 4 cylinder
It makes sense. That is just what I've always been told to do.
Old Jun 27, 2004 | 06:58 PM
chio987's Avatar
Engine: 305 4bbl HO
alright zNucleaRz, i did what u sed to do and it worked...i think...it's back to the way it was with slightly firmer shifts. 1st gear shifts @ 2500 @ 15 mph 2nd gear shifts @ 2500 at 27 mph and 3rd is at like 2500 at 45 mph, i think...does this sound all right???
also, i've heard a few people say just to put it til it feels right, but what feels like right maybe not be right. so if it's adjusted worng then won't it mess up the tranny.
Old Jun 27, 2004 | 08:21 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Sounds right with your gears I have 3.23's and mines more like 1200-1500 at same mph so sounds right. If it feels good to you its good if you think its a little to firm push the slider out toward the radiator a tad to loosen the shifts. It should also shift at 4500 at WOT.
Old Jul 1, 2004 | 01:20 AM
gta ta's Avatar
Spray some WD-40 behind the D button. Mine won't ratchet unless I spray some lude in there. Wait a few seconds and depress the gas pedal.
MM2Robinson
Oct 1, 2017 09:16 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
