Wheres the plug I pull to bleed my clutch!?!?!
Old Apr 8, 2001 | 12:49 PM
RS'er's Avatar
PLEASE help my baby is out there on jacks right now and my haynes manual isnt helping me at all. I need to bleed my clutch but I cant find the stopper to pull so I can drain my fluid...HELP!
I'm the proud owner of an '89 Camaro RS w/ 70k miles and a 5 spd manual.
"CAMARO:
The only thing close to it is its shadow."
Old Apr 9, 2001 | 02:27 AM
89ROC's Avatar
I dont think there is such thing. Just fill the reservoir, then pump the clutch like 20 times. Check the fluid again.
That's what I did, and it worked for me.
HTH!
Old Apr 9, 2001 | 04:03 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
There was a bleeder fitting on my '87 IROC T-5 clutch slave cylinder. I believe I used a small allen wrench and found the fitting on the top or side of the slave cylinder down by the clutch fork. I'm pretty sure it was the top. I bled it like a brake line with my wife pumping the clutch pedal. I recall the fluid squirting safely to the center of the car. The fitting was small enough to overlook and may be covered with grease and grime.
Good Luck!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
Old Apr 9, 2001 | 05:23 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Phil is right!
I was trying to remember bleeding mine and having no luck 'til I read his post. you've gotta reach up and around the slave cylinder and stick the right size (?) allen wrench in there. there's a port that sprays the brake fluid out and it hits the oil filter and runs down into your hair (or drain pan if you plan ahead ).
since you're looking for a "plug" I'll fill you in on how to bleed incase you're unsure.
1. fill the reservoir (to the full line or so)
2. Open the bleeder valve.
3. Have someone else push the clutch pedal down and hold it. (push down SLOWLY for best results)
4. Close the bleeder valve
5. Have your helper let up on the pedal.
6. Check the fluid level in the reservoir every so often to make sure you don't run the master cylinder dry (as long as you have some in the reservoir at all times...all is well )
7. Repeat until you don't have any air trapped in the system.
Clem
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission---FOR SALE---
Looking for a V8, preferably 4 or 5 speed Camaro with NO T-tops (wanna trade?)
[This message has been edited by clemsparks (edited April 09, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
Bert87
Aug 23, 2015 03:50 PM
wayshegoes
Aug 17, 2015 12:00 PM
rsrmoore
Aug 7, 2015 08:44 PM
