White smoke and shaking
Old Jun 29, 2004 | 07:34 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
Ok,
So I start up the car and i see a lot and i mean A LOT of whitish smoke all around me. The whole car is shaking a lot more than normal. I step on the gas and It sounds like its gurgling like bubbly. I also have lost a lot of torque. It sounds like crap. Its a stupid 305 which im swaping for an LT1 sometime soon but now i dont know what the hell is wrong with it. Its not a tranny mount cause its not cracking or jumping.
Old Jun 29, 2004 | 07:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
White smoke usually means its burning coolant. Does the exhaust smell sweet?
Old Jun 29, 2004 | 08:42 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Sounds like a blown head gasket. Pressure test the cooling system and do a compression and leakdown (if needed) om the cylinders.
Old Jun 29, 2004 | 09:34 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
actually my coolant levels are fine. My oil on the other hand was messed up. When i checked the dipstick i showed almost nothing. I added 4 quarts and the car was still running as crap.
Old Jun 29, 2004 | 09:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yea, whitish usually indicates coolant is finding it's way to the combustion chamber. When you yank the dipstick, does the oil look like a milkshake (indicating coolant is mixing with the oil)?
I agree with what's been said above, smell the smoke and do a compression/leak down test.
Old Jun 29, 2004 | 10:11 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
dipstick looks fine. If it was burning coolant, wouldn't i have to keep refilling it?
Old Jun 29, 2004 | 10:13 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
i was impressed i almost had no oil and yet there were no puddles of oil anywhere. What if the smoke is whitish almost really light blue?
Old Jun 29, 2004 | 10:23 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Bluish tint is oil finding it's way to the combustion chamber.
At what rate does it lose oil? Like how long does it take for it to go a quart low? And does it lose oil as it sits? I'd suggest a big time intake leak or your rings are shot/gap-aligned.
Does it smoke constantly? Just at startup? Just at WOT?
Old Jun 29, 2004 | 10:59 PM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
my car has been whistling for a long time now. It sounds like a leak, possibly from the intake since it gets higher pitch when i give it some gas and the butterfly opens. The last time i checked was probably 3 weeks ago and the car needed a little oil and when i checked it yesterday it had almost none. There is A LOT of smoke when i turn the car on. Sometimes when i put in reverse. I don't see any while im driving. Also, it takes a long time to get the car going when cold, i have to pump the gas pedal to get it going while turning the ignition.
Old Jun 30, 2004 | 03:05 AM
84 firechicken's Avatar
Car: 84 firebird
Engine: 305 h/o
Transmission: auto for now
i have this exact same problem right down to the shaking but as for the oil part i know were mine is going i have a leak out the back of my intake when u punch the gas does ur car die after bubling liek that for a few seconds?
Old Jun 30, 2004 | 08:01 AM
EvilCartman's Avatar
Car: '82 Z28
Might be just an intake gasket gone in the lifter valley sucking up the oil then burning it creating a ton of smoke. Also acts like a big vacuum leak making it not run good.
Old Jun 30, 2004 | 08:11 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Is the engine freshly assembled? What condition would the intake be in, particularly the gaksets.
Old Jun 30, 2004 | 10:10 AM
moreyes's Avatar
Car: 85 TA
Engine: 305 tpi
Transmission: 700
yeah, when i finally get it going and i give it some gas to leave the house in the morning it almost dies. It will hesitate a couple of times and then go. Supposely the guy who sold the car to me put this engine in a few months back. I had talked to the mechanic who did it and he didn't know anything about engines. I'm sure he did a horrible job.
Old Jun 30, 2004 | 09:04 PM
Car: 84 firebird
Engine: 305 h/o
well i might find our problem yet seems my car has had trouble i wnt out tio start it this morning and noticed a puddle of oil under the engeit was coming from the front oil pan seal so im goina pull the motor and rebuild it from the ground up so i know it will be right in everyway and if i find anything unusuale that could be causeing this problem il let u know
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
