quick question on steel braided hoses
Old Jul 5, 2004 | 01:29 PM
raptere's Avatar
Car: 1991 Camaro Z-28 (Durango R/T)
Engine: 383 L98 W/ HSR
Transmission: 700R4 Tuned Shift 2600 Stall
Axle/Gears: 3.73 10Bolt Posi W/ Al Cover, Disks
To attach the hose end connectors to the hose do you have to remove the steal braided cover from the part inserted into the conector? i cant seem to get it to fit with the cover on. also are there any tircks i should know for connecting a similarr addapter to a solid line. These are all for fuel plumbing, for my HSR.
Thanks for the help,
Eli
Raptere
Attached Thumbnails quick question on steel braided hoses-my-car-thign-copy.jpg
Old Jul 5, 2004 | 01:54 PM
ede's Avatar
ede
no you don't need to remove the stainless braid. i use crimp on ends, cheaper and easier, but not reusable.
Old Jul 5, 2004 | 01:58 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
I had a hell of a time getting my ends all the way on too.
So i decided to heat up the ends while partially on the hose a bit to see if that would make it any easier.
It did...i had the end about half way on and couldnt get them to seat all the way in...so i just heated it up with a lighter a bit..and i guess it made the hose a little softer and it slide the rest of the way in...
whether thats the proper way or not..it worked for me
Old Jul 5, 2004 | 02:17 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i wrap the stainless end with 2 wraps of electrical tape.keeps the wire from fraying.you can remove the tape with needle nose after the outside fitting is on.
Old Jul 5, 2004 | 03:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Squeeze the braid in a little bit with a hose clamp while you put the end on.
Old Jul 5, 2004 | 04:52 PM
raptere's Avatar
thanks ill have to go try thoes things
any suggestions on any thing else
Old Jul 5, 2004 | 05:18 PM
raptere's Avatar
hey another question, for starters i got them on but do you have to be able to get the electrical tape off, because i dont know if i can? and also to cut the braided line should you snip it use a cut off disk to cut it or use some kind of band saw to cut it cleanly?
thanks again
Old Jul 5, 2004 | 05:22 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Aeroquip fittings NOT Russel or Earl. Been there done that as everything in my car is now AN fittings, fuel, tranny, brakes. Brand DOES make a difference. I just did the electrical tape and diegrinder with cut-off wheel. the Aeroquip female end that goes over the braided hose is just a wee bit bigger than the other brands and makes screwing them on the braided 50x's easier. Would've been 100x's easier but it was muggy and the sweat kept getting in my eyes!
Old Jul 5, 2004 | 05:24 PM
IHI's Avatar
IHI
thanks again
I always removed the tape before I threaded the ends on the braided hose. Personally had great luck with the cut off wheel. Just be sure to blow out the lines before connecting.
Old Jul 5, 2004 | 10:51 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
When i did my tranny lines i used a line cleaner solvent to make sure there was nothing in them. This also seemed to make the lines slide in to the fittings much easier.
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
