Need Help Engine problem
Old Apr 11, 2001 | 02:53 AM
383GTABoy's Avatar
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
Having trouble getting my new 383 on the road
OK Here's the problem.
The car will start just fine sometimes, I mean just fire up the sec i turn the key but other times it just turns. It is getting spark because it is setting my timeing gun off. It is also getting fuel because I can see it come out of the exhaust. Yet I Cant get it to even fire much less start.
I have taken the entire tuned port, distributor and coil out and checked all connections and even tried a diff coil.
I really need Help.
Thanx in advance
Old Apr 11, 2001 | 05:34 PM
383GTABoy's Avatar
Engine: 383 4 bolt
Come on somebody has to have an idea.
I have had many people tell me diff things
Like i dont have enough voltage going into plugs or i need a new battery but it turns the starter just fine.
Please help come on any ideas at all im desperate.
Thanx in advance
Old Apr 12, 2001 | 12:34 AM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Well, if you got fuel and spark, it's either not enough fuel (do pressure checks, and injector flow checks) or it air delivery, not enough compression?, restricted airway?
I lied, it could be the computer control/sensors. MAF (if equipped) reading properly when it's not starting, use injectors firing 100% of the time?
That's all I can say, I haven't had this prob. Although maybe 5% of all my starts it does this, but I believe this is related to my (yes still) blown fuel pressure regulator, which I intend on fixing this weekend
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
SLP 1 3/4" headers, 3" cat back (stock cat )MSD ignition. MSD Blaster SS coil. More soon when funds are avail...
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
