350 Heads Question
Old Jul 6, 2004 | 05:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
350 Heads Question
Currently have 305 TBI LO3. Dreaming and scheming of a 350. I currently have #416 heads, ported & polished, with 1.94 in and 1.5 ex valves, and 1.6:1 rockers on my 305. I was told, and have read somewhere here, that I could put the #416 heads on a 350 block.
But I'm an idiot - I understand the smaller heads would make higher compression, but I don't know what the ramnifications of this are - please tell me why or why not I would want to use these heads, assuming I ever get the 350.
Old Jul 6, 2004 | 05:55 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Compression ratio is exactly that the ratio of the full cylinder volume versus the volume of the cylinder when the piston is all the way up + the head gasket volume + the combustion chamber volume. So its full volume / combustion volume.
Old Jul 6, 2004 | 08:52 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You'll make more power (with higher compression rather than lower compression)
and likley need to use high(er) octane fuel.
How much compression you'll end up with by bolting your 305 heads on a 350 depends on a number of factors.
1) The cylinder heads combustion chamber volume.
You've modified the head so it will not be the same as stock, measure it.
2) The piston clearances on the 350 motor.
(deck clearance, valve relief volume, dish volume. head gasket volume)
Plan on having to use 92 octane or better.
Other than that they work well on a 350.
Old Jul 6, 2004 | 10:23 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
If/when you do get the 350 block, you could have the block decked. This will allow you to run higher CR w/o the additional octane. Just have to be sure of your valve clearances between the pistons and valves like F-Bird said.
Old Jul 6, 2004 | 10:43 PM
ljnowell's Avatar
Always under the impression that compression is compression?
Old Jul 6, 2004 | 11:41 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I have the exact same hopes and my uncle has a 70's 355 with 10:1 pistons. I'd need heads/cam/valvetrain and headers and stuff. Using my 305 heads would be nice and was the plan. My thing is... the 355 cylinders are 4.03" in diameter...won't the 305 heads be too small to fit on the 350 cylinders... kinda like the pic I've attached below?
Old Jul 7, 2004 | 12:03 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
No the difference is the combustion chamber size not the port or runner size. Some 305 intake runner ports are actually much larger then 350 heads.
Old Jul 7, 2004 | 01:08 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Your reasoning is quite correct but the difference in diameter is small (only about a tenth of an inch all the way around) and as long as the head gasket successfully seals the combustion chamber to the block you're good to go.
Old Jul 7, 2004 | 08:47 AM
Car: 1997 Corvette
Hmm I figured it was small, but I also figured that would leave some weird pockets in the combustion chamber (where the overlap is) that might not be good...but I do realize they are small. Then again, if people have been doing this, it might not be all that bad of an idea
Old Jul 7, 2004 | 09:24 AM
ljnowell's Avatar
Its no worry, I run a .40 over 350 with 305 heads.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
