Rod Installation
Old Apr 12, 2001 | 10:02 PM
johnyIROC's Avatar
Rod Installation
Does it matter which way I install these rods? I notice that the bearing seats are countersunk more on one side than on the other... is this for a particular reason?
Old Apr 12, 2001 | 10:07 PM
Vader's Avatar
Johnny,
YES! DEFINITELY! There is only ONE correct way to install con rods. The larger chamfer is supposed to be installed adjacent to the crank counterweights. If you had marked the rods before removal, you would have a good indication of the proper position of the new rods (or old replacements). Also, if the rods have oil spurt holes, they should be installed facing the bottom of the camshaft.
There are other marking means used by various OEM and aftermarket manufacturers and rebuilders, including arrows on the bolt bosses, dots, dimples, punch marks, etc., but the larger chamfer must mount to match with the crank throw fillet/radius.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
[This message has been edited by Vader (edited April 12, 2001).]
Old Apr 12, 2001 | 11:49 PM
johnyIROC's Avatar
Thanks Vader... I just found the same information in the "MOTOR AUTO REPAIR MANUAL 5th Edition"
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
