compression ratio
Old Jul 11, 2004 | 02:52 PM
88Z's Avatar
88Z
Car: 88 Iroc
compression ratio
What kind of compression would i get with a stock L98 block and 083 heads milled .010?
Old Jul 11, 2004 | 06:22 PM
ede's Avatar
ede
zero you'd need pistons and gaskets along with some other parts plus you'd need to know the specs if you had pistons and all the other parts
Old Jul 11, 2004 | 06:58 PM
88Z's Avatar
88Z
Car: 88 Iroc
Just for kicks let's say stock everything, which would make it 9.3, except for heads milled .010
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
You may want to do a little search, I don't recall the cc's of those heads off the top of my head.
Old Jul 11, 2004 | 07:00 PM
88Z's Avatar
88Z
Car: 88 Iroc
C'mon guys, it's a freakin stock L98 with original heads, i'm just wondering how much milling them that much would change my compression ratio
Old Jul 11, 2004 | 07:04 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
And quite honestly I freakin' don't know. I told you to search because I know RB has answered these type of questions before and that guy has all this sh*t memorized.
Seeing as I can't make him magically appear, the next best thing I can tell you is to search. Go to the tech area, get the regular info and then use google to figure it out. I'm not going to do that for you and it's not that difficult to do, just time consuming. Or you could wait and see if RB sees this, or you could PM him.
Old Jul 11, 2004 | 07:08 PM
88Z's Avatar
88Z
Car: 88 Iroc
Awesome, thanks for the advice. I tried doing a search on here, but i gotta admit, it was a half-assed attempt.
Old Jul 11, 2004 | 07:10 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
The Technical articles don't come up on a search. They are off the Home page.
Old Jul 11, 2004 | 08:06 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
milling the head .010" will chop off about 1.5cc's
If you use the same stock type .015" shim head gasket
as origional your cr will be 9.5:1
if you reinstall the head with a replacement .040" composite gasket your cr will be lower than stock even with the head milling. 8.98:1
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
