voltage across starter solenoid when hot
Old Jul 11, 2004 | 07:30 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
My 89 GTA is not starting when hot. So I replaced the solenoid. Now the problem is even worse.
I ran the car for 30 min to heat it up then I measured the voltage across the solenoid when turning the key to start and it was 11.5V. The car would not start.
I ran a garden hose on the starter for 10 min to cool it down. The car then started. I pulled the distributer wire and turned over the starter while measuring the voltage across the solenoid switch. It was now 0 Volts.
Seems to me my problem is the solenoid? I read the tech article on the remote solenoid but I did not understand all the wires going to the new solenoid.
Old Jul 11, 2004 | 07:35 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Check yout groung to the block and make sure the threads of the starter bolts are clean, maybe a dab of antisieze.
Old Jul 11, 2004 | 09:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Is that little strap that goes from the solenoid to the starter motor properly attached? Are the rest of the wires properly attached? Good CLEAN connections?
Old Jul 11, 2004 | 10:32 PM
Car: 89 GTA
Axle/Gears: 4.10
plan
Connections are clean, it's a new solenoid. Ground wires looked OK between battery/block and head/chassis.
This is my theory and the current battle plan:
I bought a cheap Neihoff solenoid. I think my start wire voltage going to the start terminal on the solenoid "S" is not 12.4 volts, more like 10-11V when the wire gets hot, they are routed from the firewall around the front of the engine and down to the starter. I think this solenoid is much more fussy about the voltage being too low to energize it.
When I turn the key to the start position there was 11.5 V between the "BAT" terminal and the starter post. Should be zero.
I am going to install a Ford solenoid on the strut tower area and run a new wire to the GM solenoid "BAT" terminal, and short the "BAT" and "S" terminals together. This should give it a full 12V when hot.
I will post results hopefully this is it.
Old Jul 14, 2004 | 12:13 AM
Car: 89 GTA
Axle/Gears: 4.10
problem fixed
Well, I installed a remote Ford-style solenoid on the strut tower and I didn't have any hot start problems today. It looks like my problem was caused by low voltage on the start pin of the stock solenoid.
I shorted the start and Battery pins together on the stock solenoid with a piece of metal. I drilled holes in it.
I then ran a new battery cable from the new solenoid to the stock solenoid. Here is a picture of the remote solenoid.
Attached Thumbnails voltage across starter solenoid when hot-remote-solenoid-ta.jpg
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Racerx974
Sep 19, 2015 10:16 AM
corey8084
Sep 17, 2015 02:56 PM
Formula_88AE
Sep 3, 2015 01:47 PM
