Ahh it's dying on me!
Old Jul 13, 2004 | 12:33 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Yeah, it almost did it in the middle of the street yesterday!!
I did a search on this, but couldn't find anything that described my exact situation.
Here's what happens:
I start it. Note that this will happen whether it's hot or cold.
I'll usually give it a little gas just after it's started to smooth out the idle that will otherwise clunk around 550 and 490 approximately.
I'll put it into gear (reverse, 1st, 2nd, drive or overdrive) and start to move. Now, if it's going to die, which it does approximately 45% of the time, it will die within the next 30 seconds. After it dies I wait a few minutes, floor the gas, crank the engine, and it will start back up and won't die again.
I'm thinking maybe a bad coil? I have no idea if it was ever replaced on my car.
If anyone has had a similar situation, could you enlighten me as to the end solution? Thanks!
Old Jul 13, 2004 | 02:32 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: Ahh it's dying on me!
Originally posted by urbanhunter44
...the idle that will otherwise clunk around 550 and 490 approximately.
That's the key right there. What's you're carb sticker say the idle should be? Do you have any vacuum leaks? Choke sticking? Dist. cap cracked or carbon tracked? And most important - What is the state of tune??
Old Jul 13, 2004 | 04:00 PM
Car: '72 Chevy Nova
Transmission: TH350
uhh the sticker is gone lol. its the stock quadrajet.
No vacuum leaks, don't know about the choke - how do i check?
distributor cap is fine. tune-up is fine, although it probably needs a new fuel filter, but i heard that the filter won't restrict fuel flow that much so i don't think that's it.
Old Jul 14, 2004 | 02:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Idle should be around 700-800 rpm. At least, thats what the sticker for my L69 said.
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
