distributor problems
Old Jul 13, 2004 | 10:13 PM
sockfootball22's Avatar
Car: 84 z28
i have an 84 z28 camaro with a 305. I got the car from my brother and he took out all the ac crap and the brain for my car. I replaced the carb with an edelbrock 600cfm. that made it run better. but the distributor thats on it now isn't a vacuum advance distributor. how much of a difference will it make if i put a vacuum advance distributor on it? will i get better gas mileage? It looks like it would be a tight fit on gettin the distributor out and putting the new one in. I wouldn't have to pull the engine would i? Also what would be a good inexpensive distributor to get if I have to change the one I have in it now? Thanks for all the help in advanced
Old Jul 13, 2004 | 10:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If your car has a non-cc carb (which it does) it needs a non-cc distributor, aka- vacuum advance. For about $152, Mallory has a HEI setup with coil. I have one, it's a pretty decent piece. It comes with an assortent of advance springs so you can adjust the rate that the advance kicks in.
Old Jul 13, 2004 | 10:56 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
no you dont have to pull the engine to get the distributor out of the car just take the wires and cap off and loosten the hold down bolt and remove it and the hold down clamp then pull the distributor but remember to mark the rotors location so you dont have a very hard time putting it back in the correct position
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
