questions on stroking a 305 ..
Old Apr 15, 2001 | 01:01 AM
91camaroRS's Avatar
ok i bought a 350 now i tore my old LO3 apart..i got it down to the block now my question is when i rebuild it if i put a 350 crank it would be a 335 or something around there right.. but is there anything else to stroking the motor .. if so i would liek to do it cause i want to keep the block instead of throwing it away and getting another 350...
350 bored 30 over ..882 casting heads ..comp cam..hooker headers.. 700r4 corvette servo .. 3.73 and SLP posi no hood on the car , holley 750 CFM, performer RPM intake.. and umm couple other things here and there
Old Apr 15, 2001 | 01:27 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Your post is a little confusing but YES, if you put a 350 crank in a 305 you can build a 335!!! However, you have to have that 305 block clearanced for the 350 crank....you can't just stick the crank in there and make it work!! Also, it's a STROKER so you have to buy special 335 rods and pistons!! With all the money you would be putting into that you could build a 383 stroker outta that 350 block!!
Always remember.....THERE'S NO REPLACEMENT FOR DISPLACEMENT!! More Cubes = More Power!!
Old Apr 15, 2001 | 01:48 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
No, No, No. The 305 and the 350 use the same length stroke, 3.48". The 400 uses a 3.75" stroke crank. If you stuck this in a .030 over 305 (.030 over) you'd get 334. Stick the 3.75" crank in a 350 (.030 over) and you get a 383. Stick a 3.48" crank in a 400 block and you'll get a 377.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Apr 15, 2001 | 02:03 AM
I knew I was missing something!! Sorry about that! It's the 400 crank, not the 350 crank!! Couldn't remember since I pondered the 334 for about 2 hours and then decided it's a waste of money!!
Old Apr 15, 2001 | 09:33 AM
ede's Avatar
ede
well i like odd ball engines and combinations. if you wanted to stroke the 305 you need to know going in you'll spent the same money or more and not go any faster or quicker tan if you spent it on a 350 or larger engine. with that said i've got a boat load of money in a 266 v6 for a 85 camaro drag car. i also have a 336 in a 68 ss camaro. just to be normal i built a 355 for my sons camaro.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 15, 2001 | 11:07 AM
84CAMAROHIGHOUTPUT's Avatar
what do one of these 400 cranks cost?
Old Apr 15, 2001 | 11:13 AM
SUPER-SPORT-CHEVY's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 84CAMAROHIGHOUTPUT:
what do one of these 400 cranks cost?</font>
Iron eagle has 400 cranks for about 400$
If you really want to be original slap in a TURBO DIESEL!
Old Apr 15, 2001 | 12:53 PM
<font face="Verdana, Arial" size="2">Originally posted by SUPER-SPORT-CHEVY:
</font>
Whoa there...don't go wasting $400 on a 400 crank!! For about $600-$700 you can buy a complete 334 kit from Powerhouse out of california and the kit comes with a NEW stroker crank!! They don't have an on-line catalog but go to www.enginekits.com and you can get their email address to request a catalog by mail!! That's where I'm getting my 355 kit from! Also, almost all of their kits come balanced too!!
Old Apr 15, 2001 | 10:15 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
it's a good point, 350 crank in a 305, gets you a 305 with the wrong crank. and using a 400 crank is about a big waste of time and money. if you want to stroke one, buy one new made to fit your engine, not one needing to be cut down to fit. currently working on a destroked version with a guy making 269 using crank and rods from a L99 and 305 (.040 over) pistons. planning to run it 7k.
84z96L31vortec
Aug 20, 2017 12:16 AM
dutch930
Sep 11, 2015 06:58 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
