accelerater feels like a BRICK when i step on it..
Old Jul 16, 2004 | 01:54 PM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
Axle/Gears: 4.11 12 bolt
really have to push down hard on the accelerater to get the car to move, almost as if its stuck, what do i got to do to get it fixed?
(92 rs 305)
Old Jul 16, 2004 | 04:02 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Tuned port or throttle body. About have to be a binding in the spring or the throttle shaft. Try some carb cleaner on the spring and inside at the throttle blades. Then some light oil. Could be the cable but not usually.
Old Jul 16, 2004 | 04:21 PM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
throttle body inj...
Old Jul 16, 2004 | 04:29 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
the tbi base is worn around the throttle shaft. It wears off-center due to the forces on the shaft. When there is alot of vacuum present, the throttle shaft is pulled down and the throttle blades lock in the bores and cause the 'brick wall' feeling when you first hit the gas.
Old Jul 16, 2004 | 04:32 PM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
k,so what will i need to fix this problem?
Old Jul 16, 2004 | 04:34 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Either have the tbi base rebushed, or replace the tbi.
Old Jul 16, 2004 | 04:35 PM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
any site were i can go to order?
Old Jul 16, 2004 | 04:46 PM
Car: 88 Camaro SC
Engine: SFI'd 350
www.turbocity.com sells rebuilt slightly overbored GM units. Pricey but theyll fix the problem. Other solution is to visit a junk yard and try to find a decent one thats not too badly worn. You could also have it rebushed. Dont know who does that stuff. Automotive machine shop, perhapse?
See how much slop is in the present tbi. Open the throttle up about 1/4 of the way and try to move the shaft around. If it moves alot then its time to fix it. Ive gotten around a little bit of slop by bumping up the min air adjustment. Not so much that it affects the stock idle speed, but enough to prevent some of the binding.
Old Jul 16, 2004 | 04:58 PM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
i noticed your from nj, jersey city here<<
so why not i try to find a used one, its called a throtle body injection thingamagig..
Old Jul 16, 2004 | 05:17 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Probably a junkyard is the cheapest way. The thing you want is the tbi base. Youll probably have to look at alot of them untill you find one thats not too worn to be used. Any detectable up and down/sideways movement in the throttle shaft and itll do the same thing your present one does.
Im all but certain that the tbi is the problem but as a final check you can push the accelerator down with the engine off. If it moves freely then the worn tbi is the culprit. If it feels the same then something may be binding.
Old Jul 16, 2004 | 07:32 PM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
it presses down just a bit lighter than it does when the motor is running. ive also noticed that when the car is in park(idle) , when i step and let go the gas , when the motor revs back down ,there is a hiss/cringing noise ...
Old Jul 16, 2004 | 11:00 PM
Car: 88 Camaro SC
Engine: SFI'd 350
hmmm... usually there is a big difference when the motor is off vs. when the motor is on. It also only has the brick wall feeling when you first hit the gas. Disconnect the throttle cable and check that it moves freely and that its not binding up in its housing.
Ed1LE
Sep 30, 2018 09:14 AM
Gunner242
Dec 25, 2015 04:49 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
