can't get more than 24° mechanical advance
Old Jul 21, 2004 | 07:18 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I bought a spring advance kit and put the lightest spring on. With 14° initial timing I'm still getting only 24° total at 3000rpm, with vacuum advance plugged. With my original springs I was only getting about 28°.
Old Jul 21, 2004 | 07:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Try using the factory weights and aftermarket springs.
Old Jul 21, 2004 | 07:52 PM
Car: '87 Camaro LT
Engine: 355 L98
That's not a bad idea. Good thing I saved them.
Old Jul 21, 2004 | 08:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Make sure the cam plate on top of the dist shaft isn't installed upside-down.
Old Jul 22, 2004 | 12:11 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which kit do you have?
Old Jul 22, 2004 | 01:19 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
ditto, the weights should act against the rounded part of cam.
My Summit Racing HEI(believe its a re-badged ACCEL) came out of the box with the cam upside-down.
don't know if you have a GM hei or what, but if you have a summit or accel dist. 14* is about all those cam plates allow.
Old Jul 22, 2004 | 06:57 AM
Car: '87 Camaro LT
Engine: 355 L98
I installed the cam plate the way they had it in the diagram on the package. The kit came from Autozone's "performance" section (maybe that's the problem lol), not sure of the brand off hand, I'll check when I get home from work. What someone else told me is with the weak springs I'm already getting advance at idle and there isn't much room left above idle for the advance to increase.
Old Jul 22, 2004 | 09:46 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The weights that come with the Mr. Gasket kit are worthless. I second the motion for stock weights and different springs.
gta892000
Aug 11, 2019 11:16 AM
Jorlain
Oct 8, 2015 01:57 AM
webeeZ28
Sep 14, 2015 12:00 PM
angel2794
Sep 8, 2015 06:22 PM
jtwoods4
Sep 3, 2015 05:39 PM
