steering pull
Old Jul 21, 2004 | 07:20 PM
Airpak's Avatar
Car: 1982 Camaro Z28
Axle/Gears: 10 bolt auburn posi 3.73
steering pull
my car was pulling/leading sorta from side to side sometimes ...
but then
i just got my lower balljoints replaces on both sides and a wheel alignment and it seems a bit better. but it still does a little bit? could it be because of the worn tires? or should i go back and complain? i also have to change the power steering pressure hose, will do that tonight... but is there another reason it pulls sometimes? or did they **** me over?
thx
Old Jul 21, 2004 | 07:55 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
if the tires are worn funny then replace them that is gonna make the car pull also check the tire pressure and make sure its not low
Old Jul 21, 2004 | 08:11 PM
Airpak's Avatar
yeah. my rims are on their way =P. ordered them last wednesday i think.
anywho..
any ideas on how to loosen up this g*d damn power steering hose? what can i put on it? its so tight. not moving, n its soo hard to get in theree..
thx
Old Jul 21, 2004 | 08:14 PM
THEGENERAL's Avatar
you talking about on the back of the pump or the steering box its self ? if you mean the pump your better off to take the pump off and change it , if your talking about the steering box we use a open end wrench on it works just fine
Old Jul 21, 2004 | 08:43 PM
Airpak's Avatar
grr.. i got the bottom piece off. but the top ones still stuckk.. is there anything i can put on it to loosen it? luuube it up? theres not much room for a wrench. i can use a tiny one, but its useless.
Old Jul 21, 2004 | 09:00 PM
THEGENERAL's Avatar
are you replacing the hose ???? if so just cut it off and use a deep socket and take it off with an extension ...works every time
i know its not the "correct"way of doing it but it does work
Old Jul 21, 2004 | 09:33 PM
LottaBallsCamaro's Avatar
:Have you replaced your tierod ends? That is usually the culprit to a "loose" steering wheel. Does it pull to either side or just one? Your steering box could also use replacing.
Old Jul 21, 2004 | 10:21 PM
Airpak's Avatar
:P just wat i did...got it thx!
i dont even know wat tierod ends are =( . be nice.
im a complete newwwb, but i am trying.
it pulls to either side.i think it might be my tires.
the back one must be leaking air, its at 15 :P while the rest are at like 38
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Aug 31, 2015 07:00 AM
Victor6
Aug 30, 2015 02:09 AM
zayne0
Aug 24, 2015 07:22 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
